![]() | Home > Maintenance & Mods (L322) > Help for a noob thicky!..fbh fuse |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
There is a thread here that may help?
Dstew Member Since: 26 Dec 2020 Location: Kent Posts: 42 ![]() ![]() |
Thanks but there are so any different opinions on that thread with no definitive answer. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
The electrical diagrams detail a fuse for the FBH and a fuse for the receiver, if you need that specifically. Can’t help with fuse location I’m afraid.
Bluespanner Member Since: 03 Jan 2021 Location: Burton up on Trent Posts: 43 ![]() ![]() ![]() |
Just disconnect the battery. You will need a 10mm spanner. |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 890 ![]() ![]() ![]() |
If you’re removing the fuse to pair the fob, no need - remove the right hand compartment cover in the boot, you will see a black module around the size of cigarette packet with a Webasto sticker on it, remove the black connector, it’s quite stiff but will just pull out. Leave disconnected for 10 seconds, replace and immediately press & hold the off button on the fob, the red led on the fob will illuminate then go out, pairing is then complete. |
Thanks for your answer but I want to do a FBH reset. Also I would rather not disconnect the battery and have to reset clock, steering, windows etc |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
The WM does say battery disconnect to reset the FBH. But try MJD's fuse suggestion to see if it works.
Where would I find junction box engine? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I don’t know why but it is always the folding mirrors on mine that get out of sync, but opening and closing the drivers door a few times usually sorts it.
On this page, it says Fuse 59.... in the glove box is FBH......
