Home > Technical (L322) > Type and size of torx screws for height sensor?
tinribs
2010 Range Rover Vogue SE TDV8 Galway Green
Does anyone know the type and size of the torque screws required for the height sensors? I assume they are the same on all L322's, but ours is a 2010 3.6tdv8 if that makes any difference?
Thank you!
Post #581695 30th Jan 2021 1:04am
dhallworth
If Microcat is right, they are Part HS1 on the attached diagram.
HS1 is an M5 x 12mm Torx bolt.
David.
 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #581696 30th Jan 2021 1:25am
