Home > Technical (L322) > 4.4 tdv8 rear sump bolt
t5pete
Does any one now the purpose for the rear sump bolt as the cross member is in the way for draining.
Thank you
Post #580274 18th Jan 2021 3:47pm
Baltic Blue
The 4.4 tdV8 was specifically designed as a “top down maintenance car” ,
Forget draining the sump from the bottom and use the suction tube from the top.
It is so much easier, cleaner and quicker.
Post #580278 18th Jan 2021 3:59pm
t5pete
I understand that Mike but as land rover call it "mini sump" I would like to know its purpose as there's a main drain on the side and this which I questioned too.
Also having a ramp of my own I prefer to drain properly/fully rather than a suction pipe, don't get me wrong they have designed it that way but my preference is gravity will always win.
Post #580297 18th Jan 2021 5:36pm
Baltic Blue
I appreciate your preference Pete..
I was never a fan of sucking oil out, but having seen how much I get out and reports from Nino whose opinion I respect greatly.
He sucked his out then went further and removed the 2 sump plugs but only got out an extra couple of spoonfuls, so, each to his own.
Cheers
Post #580303 18th Jan 2021 5:53pm
DrRob
It’s a drain for turbo pipe I think. Drain it when you drop the oil from main drain. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #580329 18th Jan 2021 7:11pm
t5pete
Thank you Rob I'll see how much comes out on the next oil change.
Post #580334 18th Jan 2021 7:23pm
mpirie
I have to admit to being a convert to sucking the oil out too now.
Having said that, I still open up the rear sump plug to make sure I get all the old oil out.
Mike
Post #580345 18th Jan 2021 7:48pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
As previously mentioned it's a drain for the turbo return , drain it at every oil change as it can eventually sludge up and cause turbo oil starvation (very expensive ) as the hot oil can't return to sump , same for 3.6's too , I suck the main sump dry with suction pump then drain the turbo return (a bit messy as it dribbles onto crossmember ) , standard Ford type sump plug and o ring seal , only a couple of quid so replace with a new one .
Post #581173 25th Jan 2021 11:39pm
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
Mike
I always do exactly this. Having tested it there is only a tiny amount left in the main sump once suctioned out. If you think about the oil elsewhere in the engine that will not all drain out (and the fact there is 10 l in there anyway!!) it is nothing to worry about.
I do drop that rear one though as it seems like a good idea to make sure fresh oil flows through the turbo drain. Probably not needed but it makes me happy lol
Post #581184 26th Jan 2021 8:55am
Baltic Blue
I have been monitoring the oil dilution rate since I downloaded the latest iid software.
It’s gone from 0 to 0.8 in the 2k miles I have managed between lockdowns , but given that 7 is quoted as the max level and the fact I change it twice a year under normal driving use, the small amount left in compared to the 8.5 litres of clean new oil flowing through a new filter element each time can’t possibly be much of a problem.
Post #581197 26th Jan 2021 10:31am
