Home > Technical (L405) > SDV8 Front Suspension Knocking - LTB00557v8 - Help Needed |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2485 |
I totally agree but sometimes its better to get the problem fixed then move on.
5th Jan 2019 1:32am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1382 |
Good that Lloyds have been helpful anyway. Part of the problem for them may be that the roads around Kelso are not as bad as in some other places, e.g. Edinburgh, and the smaller roads don't allow higher speeds that might show the instability. When I was trying to demonstrate a noise from the dashboard to the workshop foreman it took a long time to find a section of road that would set it off. You might consider trying to find a section of road that consistently produces the symptoms. I recall that the road (A697) from Cornhill to Wooler has some poor surfaces and bends that might work, that is not too far away travelling along the south bank of the Tweed. Only Range Rovers since 1988 |
5th Jan 2019 12:33pm |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 |
what are people's views on which part solves this issue - the valve block, the lower wishbone bushes or the struts (and then which part of the strut the damper or something else?) 2016 (L405) Autobiography in Black with Ivory - for ULEZ
28th Mar 2019 12:28pm |
CharlesA22 Member Since: 08 Jan 2014 Location: Strathclyde Posts: 33 |
The good news is that new ARB bushes on my Oct 2016 5.0 SC V8 have restored the front suspension to normal. The bad news is that this defect, which I first experienced on my Oct 2013 4.4 SDV8 straight out the showroom, has not been permanently fixed by JLR. As ever, it took multiple visits to the dealer and a "sponsored" drive with one of their techs before they accepted the "knock" was present on my latest car. On mine, the 100% reliable scenario for provoking the "knock" was passing over a traffic calmed raised junction whilst turning left. This caused the n/s/f wheel to drop off the raised "traffic calming" plinth and provoked "the knock" every time. Drove over the test route today on the way back from the garage and it behaved impeccably, smooth and well damped with no knock! FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024 |
29th Mar 2019 12:21am |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 |
bumping this thread bc I have the clunk and wobble/swaying from side to side. Also on colder morning I noticed I get a "suspension leaning fault" on the dash that goes away if engine turnoff/back on.
12th Jan 2021 7:50pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
Yes, easy enough to replace on the L405. Kev
12th Jan 2021 8:11pm |
Perfect. Thank you. The LR dealer said it was the bushings which are starting to cause the LCA bushings to wear. They wanted crazy money to pop new ARC sway bar bushings on so i bought a set myself to put on.
12th Jan 2021 9:16pm |
No, the rears are different to the fronts.
12th Jan 2021 9:34pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
It’s not a hard job, did mine on the drive, with the car on stands
12th Jan 2021 9:41pm |
Thank you for the diagram 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
12th Jan 2021 10:19pm |
So the member I think you are referring to has 3 bolts and the bushing clamp bolts to that? I took the 3 bolts off on the member of one side and tried to pry it down to get access to the bushing clamp but couldn’t pry it down far enough to get to the bushing clamp bolts...this was without removing the skid plate. It was a bit of a pain to wrestle it back into position to put the 3 bolts back in after the failed attempt. So you’re saying after I remove the skid plate I have to actually drop down the sway bar? I can’t just undo the bushing clamps and pop in the new bushing? Which bolts need to be replaced...are they on the schematic above? 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
12th Jan 2021 10:25pm |
Yes basically, if you take off the skid plate then you can drop the supports down and replace the bushings.
13th Jan 2021 9:17pm |
Yea those are the 3 bolts I removed on the one side (passenger side - US). I tried to pry the member down to rotate but wouldn’t budge a lot (maybe bc the other side was still bolted up?) once I saw I couldnt reach the nuts on the bushing clamp (to remove the bushing) I decided quit bc it was getting dark. I had a hell of a time getting trying to push the member back up to where it was. I re-used (put back in) the 3 bolts...once I put the 1 in furthers to the front bumper it helped line up the rest of the holes. The back one is the B*** bc it goes in on an angle.
13th Jan 2021 11:04pm |
Basically the clamp is fixed to the car on the member, but ther isn’t a fixed side to side position on the sway bar, when you drop it down it is free to move side to side slightly. As you will have unbolted the supports from the car, once you unbolt the clamp they are effectively off the car...So unless you get the clamp back in the right place on the sway bar before you assemble it’s possible that it will be slightly out of place on the sway bar and the holes on the support member won’t line up with the holes in the subframe as the clamp and the rubber have been moved slightly along the sway bar. The old runners will be lose and easily moved, the new rubbers are much tighter..... so more difficult to reposition the member.
13th Jan 2021 11:15pm |
