![]() | Home > Technical (L405) > SDV8 Front Suspension Knocking - LTB00557v8 - Help Needed |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
Don’t grease the bush.
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Thank you. I’ll be swapping them out when I have some warmer weather.
Might also be worth checking the pipes and fluid levels in the ARC ststem. IIRC the pipes can rust and leak, and aren’t visible as are covered by a plastic shield. There is nothing that can't be fixed with a hammer😜😜
I did that prior when I got it a year ago. It was just a hair below max so I topped it. But it barely took any. I’m pretty sure I looked again when I changed my brake pads etc. and I think we are good there. But good idea 2014 FF Autobiography 5.0 SC
