Home > Technical (L322) > Gearbox sump dripping
SteveRRL322
Good Afternoon,
Noticed a damp patch on the ground so got under it and noticed the front drivers side
Of the plastic sump to be wet slightly. It looks like it is coming from a large wiring plug
Just above as this seems wettest, Can this leak? Or would it just be the sump weeping and the oil blowing
Around? The fluid looks clear and does not smell like normal gear oil.
I have cleaned it up and re torqued the sump bolts and will check again.
Cheers
Steve.
Post #579091 9th Jan 2021 3:55pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi Steve, yes the wiring plug does leak, it has an O ring on it and its not uncommon to spring a leak. They’re not difficult to change and are usually done with a gearbox service as the plastic sump has to come off, I’m sure there is some stuff in the wiki on how to tackle them.
Post #579092 9th Jan 2021 4:34pm
SteveRRL322
Thanks Dave,
That looks like the culprit. Well looks like it will have to wait till it either warms up a bit or
We can move around again. Looks minimal so should be ok for a while.
Thanks again
Steve.
Post #579097 9th Jan 2021 4:57pm
Search gearbox sleeve on here, a few bits and bobs on it.
When you get a chance, do the fluid pan and sleeve and you will be sorted. There is nothing that can't be fixed with a hammer😜😜
Post #579099 9th Jan 2021 5:43pm
bloddy well are ... PITA to get them back in to the correct position Wink
But this certainly looks like where the leak is coming from. [EDIT removed] .
Post #579101 9th Jan 2021 6:43pm
We change them every time we service the gearboxes... Thumbs Up
Post #579136 10th Jan 2021 2:14am
SteveRRL322
I had the pan and oil changed when I bought the car four years ago by LR, but reading RRPhil guide
You have to remove a clip with the pan off to take the sleeve out?
I take it there is no way of doing it with dropping the pan?
Thanks
Post #579147 10th Jan 2021 10:17am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I'm pretty sure the locking mechanism is inside the gearbox so you have no option but to drop the pan. I remember the sleeve being a bit of a battle to get installed and resorting to a length of wood as a lever to encourage it. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #579160 10th Jan 2021 11:33am
DrRob
Martin Hind is your gearbox man over at Darford Transmissions and Autocare Thumbs Up
RR enthusiast too and LR trained Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579167 10th Jan 2021 11:44am
SteveRRL322
Thanks
Will call him tomorrow 👍
Post #579169 10th Jan 2021 11:55am
dhallworth
The 2007 car I’ve just purchased is damp in the same area so I’ve bought the sleeve and a few other bits to do when I change the oil and filter in the gearbox. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #579170 10th Jan 2021 12:00pm
Sorry, memory fails me... .
Post #579174 10th Jan 2021 12:23pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I'll 2nd Martin Hind mate. Anything I cant do on my range it goes to him.
Post #579179 10th Jan 2021 1:19pm
Maccaa
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
And thats why Craig looks after my car Bow down Current FF Westminster 4.4 V8
Post #579182 10th Jan 2021 1:48pm
dhallworth
I bought this set of seals from eBay
https://www.ebay.co.uk/itm/genuine-bmw-zf-...2749.l2649
They arrived within 24 hours of purchasing and are all stamped ZF. Well, the 2 plastic ones are, the 4 rubber dowels have different colours painted on them.
Once my oil pan and oil arrives from Duckworths I'll be doing the same job.
Here's a picture of the seals if it's of any interest.
Post #579229 10th Jan 2021 8:12pm
