Home > Technical (L322) > Gearbox sump dripping |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Hi Steve, yes the wiring plug does leak, it has an O ring on it and its not uncommon to spring a leak. They’re not difficult to change and are usually done with a gearbox service as the plastic sump has to come off, I’m sure there is some stuff in the wiki on how to tackle them. |
9th Jan 2021 4:34pm |
SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128 |
Thanks Dave,
9th Jan 2021 4:57pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Search gearbox sleeve on here, a few bits and bobs on it.
9th Jan 2021 5:43pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
bloddy well are ... PITA to get them back in to the correct position But this certainly looks like where the leak is coming from. [EDIT removed] . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 Last edited by Joe90 on 10th Jan 2021 12:22pm. Edited 1 time in total |
9th Jan 2021 6:43pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
We change them every time we service the gearboxes... |
10th Jan 2021 2:14am |
I had the pan and oil changed when I bought the car four years ago by LR, but reading RRPhil guide
10th Jan 2021 10:17am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 516 |
I'm pretty sure the locking mechanism is inside the gearbox so you have no option but to drop the pan. I remember the sleeve being a bit of a battle to get installed and resorting to a length of wood as a lever to encourage it. 2016 Skoda Octavia VRS Estate
10th Jan 2021 11:33am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Martin Hind is your gearbox man over at Darford Transmissions and Autocare
10th Jan 2021 11:44am |
Thanks
10th Jan 2021 11:55am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
The 2007 car I’ve just purchased is damp in the same area so I’ve bought the sleeve and a few other bits to do when I change the oil and filter in the gearbox. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
10th Jan 2021 12:00pm |
Sorry, memory fails me... . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
10th Jan 2021 12:23pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
I'll 2nd Martin Hind mate. Anything I cant do on my range it goes to him. |
10th Jan 2021 1:19pm |
Maccaa Member Since: 03 Feb 2020 Location: Bristol Posts: 38 |
And thats why Craig looks after my car Current FF Westminster 4.4 V8 |
10th Jan 2021 1:48pm |
I bought this set of seals from eBay
10th Jan 2021 8:12pm |
