Home > Maintenance & Mods (L322) > P0171 on 2006 Supercharged |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 579 |
On its first trip out after finally passing the MOT test which involved replacing bank 0 lambda sensor to pass the Emissions test, the engine light cam on.
1st Jan 2021 4:55pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
Hi,
1st Jan 2021 7:10pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
When I had this code a few years ago on my 4.4 petrol I seem to remember it being those pesky PCV hoses turning to blancmange that caused it. An easy thing to check, assuming yours has such hoses.
1st Jan 2021 7:21pm |
gravitylover Member Since: 08 Nov 2020 Location: Southeast NY Posts: 36 |
This happened to mine. The fix was a hack but it works. There's flexible urethane epoxy squeezed into the crack then the hose clamps to keep it from spreading again. That could be your leak by the MAF sensor. It was found when a smoke test was done to find a vacuum leak.
1st Jan 2021 8:05pm |
Thanks I will check there if need be.
2nd Jan 2021 1:10am |
Sorry for the delayed response. I don't know the details because it was done at my buddy's shop before I picked it up in October. These are the pictures he sent as he was going through it before I paid him for it and I didn't know much at that point so didn't know what to ask. |
2nd Jan 2021 3:32pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
I did loads of posts on this same engine about a year maybe slightly longer ago...
2nd Jan 2021 9:06pm |
gravitylover - thanks for your input.
2nd Jan 2021 9:46pm |
Intermittent sometimes one sometimes both. If I were you get the smoke test first - the rest may be fine and I was jnlocky - I was at 110k if you are significantly higher or lower you are probably fine Current stable:
2nd Jan 2021 10:42pm |
Thanks, I will check the garage that did my MOT as they fitted a new O2 sensor on bank 1 under warranty, if they can do a smoke test, then maybe it can all be done under warranty. If not its off to our local indie.
2nd Jan 2021 11:21pm |
Same sort of mileage as mine so it could well be some of those parts. I also did the In tank fuel filter unit and ran through a can of bg44k injectors seem great on the code reader now.
3rd Jan 2021 4:37pm |
I wasn't aware there was a date on the MAF so I will check that tomorrow.
3rd Jan 2021 6:17pm |
Checked the MAF sensor and its dated 06/11/12 so looking at the service records I can guess that it was fitted around 60k miles ago, and was probably fitted by the main dealer looking after the car over a 5 year period.
4th Jan 2021 10:44pm |
Nope wrong you are falling for my trap ... my maf said 070119 I thought set it’s only a few months old when I got that it couldn’t possibly be that that’s causing all my issues... after spending various amounts on various things i took it to a specialist for something unrelated - wheel bearing as I couldn’t get it off and he said nice car I moaned and he said probably the maf and I said nah it’s only a few months old to which he told me denso date backwards which made sense then when I changed it most of my issues went too.. yours is original my friend - change that puppy and with a denso too
6th Jan 2021 11:33pm |
