Home > In Car Electronics (L322) > Bovee Bluetooth adaptor
Landmark
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
If anyone has a 2010 or newer and are using original ipod lead connected to bovee Bluetooth adaptor, can they confirm what functions work with Android. This set up looks good for iPhone but not to sure for Android. Cheers all.
Post #575485 8th Dec 2020 1:05pm
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Hi there,
I use it and the full steering wheel controls work, ie. Volume, Track Change etc -------------------------------------
MY 2012 4.4 TDV8
Post #577158 25th Dec 2020 10:03am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
i am the same all functions work no issues just does not display any details on screen for track info seems to see deezer as one big playlist 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #577187 25th Dec 2020 7:26pm
Landmark
Well got the bovee 1000 cw ipod landrover lead wouldn't work with Android so my son tried it with his iPhone x. No joy keeps saying device error. Is there ccf files that need to be loaded to activate stereo.
Post #577220 26th Dec 2020 11:18am
Jayk69
Which bit is not working?
can you connect to the Bovee1000 with your mobile? 2012 Vogue 4.4 TDV8 - Current
Post #577371 27th Dec 2020 2:50pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Not very helpful I know, but it will likely be either the cable or the Bovee. I would start with the cable...it may be good enough to provide power so you can “see” the Bovee. But not do data.
You can also connect direct to the iPod cable to eliminate it; Either an iPod, iPhone or iPad with 30pin connector will do. Or if you have a 30 pin to lightning adapter then that will work too.
Post #577378 27th Dec 2020 3:36pm
Landmark
Found an old ipod thing and plugged it in still got device error maybe a bit of crackling noise. Anyone in Hampshire got a genuine lead I could try. If that works then it may prove that the bovee supplied lead is no good.
Post #577500 28th Dec 2020 3:19pm
What lead are you using.
It needs to be the LR lead into the multi pin connector not an IPod lead into the USB. There is nothing that can't be fixed with a hammer😜😜
Post #577505 28th Dec 2020 3:32pm
Bl4ckD0g
Yes so if the iPod direct into the 30 pin lead still doesn’t work then it’s either the lead or the socket. I would hazard a guess it’s the lead.
Post #577515 28th Dec 2020 3:55pm
Landmark
Basically brought bovee c/w a jaguar landrover to 30 pin lead.
Post #577522 28th Dec 2020 4:06pm
There is a firmware update you can do to flash the bovee
Possibly worth doing.
I’ll find the link.....
http://www.viseeo.com/ImgViseeo/20141105162914.pdf There is nothing that can't be fixed with a hammer😜😜
Post #577531 28th Dec 2020 4:42pm
Landmark
Seems that the phone connects to Bovee but won't connect to audio, just sais device error and then disconnects.
Post #577558 28th Dec 2020 8:24pm
Bl4ckD0g
If the same problem is there when connecting the iPod to the lead then I doubt the problem is with the Bovee Wink
Just change the lead and go from there. Hope it’s not your socket.
Post #577596 28th Dec 2020 11:15pm
Jayk69
What Bl$ckD0g said.
my experience with the Bovee is good i did not purchase it it was in the glovebox of the car and it just worked.
I i said you cant see any track info but i have had no issues with it, pauses when you turn ignition off re-starts when you start the car. 2012 Vogue 4.4 TDV8 - Current
Post #577644 29th Dec 2020 12:08pm
Davidmudley
I'm having a similar problem. I've just bought and installed the Invery bluetooth adapter (https://invery.com/products/airdual-bluetooth-music-streaming-adapter-for-range-rover-land-rover) and it plugs into the ipod dock in the car (2011 4.4 tdv8), seemingly getting power as the lights are on and my phone can connect to it. My problem is that it doesn't seem to then connect to the car, I can't get anything on the screen when i select Ipod from the infotainment system (I think it say connection error).
Any ideas on how i can diagnose the problem and solution?
Thanks. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #621312 25th Jan 2022 9:13am
