Home > In Car Electronics (L322) > Bovee Bluetooth adaptor |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 |
Hi there,
25th Dec 2020 10:03am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i am the same all functions work no issues just does not display any details on screen for track info seems to see deezer as one big playlist 2012 Vogue 4.4 TDV8 - Current
25th Dec 2020 7:26pm |
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 |
Well got the bovee 1000 cw ipod landrover lead wouldn't work with Android so my son tried it with his iPhone x. No joy keeps saying device error. Is there ccf files that need to be loaded to activate stereo. |
26th Dec 2020 11:18am |
Which bit is not working?
27th Dec 2020 2:50pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Not very helpful I know, but it will likely be either the cable or the Bovee. I would start with the cable...it may be good enough to provide power so you can “see” the Bovee. But not do data.
27th Dec 2020 3:36pm |
Found an old ipod thing and plugged it in still got device error maybe a bit of crackling noise. Anyone in Hampshire got a genuine lead I could try. If that works then it may prove that the bovee supplied lead is no good. |
28th Dec 2020 3:19pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8643 |
What lead are you using.
28th Dec 2020 3:32pm |
Yes so if the iPod direct into the 30 pin lead still doesn’t work then it’s either the lead or the socket. I would hazard a guess it’s the lead. |
28th Dec 2020 3:55pm |
Basically brought bovee c/w a jaguar landrover to 30 pin lead. |
28th Dec 2020 4:06pm |
There is a firmware update you can do to flash the bovee
28th Dec 2020 4:42pm |
Seems that the phone connects to Bovee but won't connect to audio, just sais device error and then disconnects. |
28th Dec 2020 8:24pm |
If the same problem is there when connecting the iPod to the lead then I doubt the problem is with the Bovee
28th Dec 2020 11:15pm |
What Bl$ckD0g said.
29th Dec 2020 12:08pm |
Davidmudley Member Since: 26 Dec 2021 Location: Surrey Posts: 80 |
I'm having a similar problem. I've just bought and installed the Invery bluetooth adapter (https://invery.com/products/airdual-bluetooth-music-streaming-adapter-for-range-rover-land-rover) and it plugs into the ipod dock in the car (2011 4.4 tdv8), seemingly getting power as the lights are on and my phone can connect to it. My problem is that it doesn't seem to then connect to the car, I can't get anything on the screen when i select Ipod from the infotainment system (I think it say connection error).
25th Jan 2022 9:13am |
