Home > In Car Electronics (L322) > My experience in installing NaviPlus CarPlay in a L322 MY10
MARIO-Vogue-SE
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Santorini Black
For now I use a Samsung, my first android in my life that I am very disappointed with. I didn't use siri to tell you how he behaves to me. Regarding Waze, it doesn't work at all with Samsung, it shows a very simplified graphics and nothing more. I'm more upset that I can't do mirroring for TomTom, with iPhone it works very well, android doesn't seem to want to accept it.
Post #568294 28th Sep 2020 5:49pm
jjfang
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
I recently installed this system. Its worked amazing since with only one issue. The issue being sometimes when the system wakes back up my whole screen goes crazy. This is generally solved by me starting the car engine or I have to start it then shut off the engine then start it back up. It happens only a couple times, was this solved by messing with the wiring? I was told from Naviplus that this is a voltage issue and the recommended me to reroute the power cable.
Post #576899 21st Dec 2020 11:18pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Can you tell me how you re-routed the power cable?
I have the same thing and I certainly suffer from voltage drop, even with a brand new battery fitted and a resting voltage of 12.7 or above I see voltage sagging below 11 volts or more.
Are you seeing much voltage drop since re-routing the power? ie: was the Naviplus the cause of the voltage sag or was the screen static a symptom of voltage sag?
Post #577169 25th Dec 2020 12:59pm
jjfang
I haven’t rerouted the power, I’m a bit reluctant to do so. Mainly I don’t want to mess with it all again tbh. I haven’t noticed any battery issues or drain issue in my rover. I wonder if our static issue is similar to robkuijpeTA where he ended up messing with the ribbon cable?
Post #577309 27th Dec 2020 5:09am
Siftah
Pretty much the same as me tbh, I'm a bit wary of messing with the wiring when it's basically working!
The static issue is definitely more prevalent when the battery is less fully charged however, so I'm pretty sure it's to do with that.
Currently a thousand miles from home and due to set off again shortly, so perhaps when I'm back I'll consider poking with the wiring a bit - I'm also not convinced the battery drain is related to the Naviplus, so it seems sensible to fix one problem before attempting to diagnose another and the battery drain is the biggest issue right now.
Will let you know how I get on!
Post #577397 27th Dec 2020 6:45pm
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
robkuijpers wrote:
JoolsB wrote:
Have a look at the NavTool unit too, way easier to fit and the end result is excellent.
I contacted them as well, but they did not want to send me their installation instructions on forehand to assess the amount of work/complexity/risk. So that's why i didn't what to take the risk with them. Good to hear that their solution is also OK
KR
RK
Apologies for resurrecting an old thread, I found it whilst googling "naviplus install circuit board".
As I'm in the UK I was quite interested to read supershuttle's post here about the kit available from 'Unique Auto Developments', the dualview version is now available to order.
As I'll shortly be removing some of the dash / gloveboxes anyway for another job I did the same as robkuijpers. Contacted the company involved (UAD) and asked for a copy of the installation manual, to assess the amount of work / complexity / risk, also to decide if I'll do it when I do the other job or wait till later & get it done professionally.
I was directed to a YouTube video which is incomplete (& the bit that isn't covered is where any single / dualview differences would be I believe). I asked again and was told "The full manual for this product has not been finalised yet, however the installation is very similar to the single view product. This product will come with the full comprehensive guide in the box that details the installation with photos.".
So I asked if they would send a copy once it's finalised / by the time the units start shipping. I received a reply stating "We can't release the full comprehensive guide that is included in the box prior to purchase, however for the time being I can send across a couple of pages from the Single View L322 manual so you can get a better idea.". The couple of pages are regarding trim removal.
If it's their product and their manual then clearly it's a case of won't send, not can't send.
I wondered, is it unreasonable to ask for a copy of the instructions to decide whether or not I'll fit it myself / get a professional to fit it / decide against the idea??
Cheers
Richard 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #635294 23rd Jun 2022 6:31pm
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
Not unreasonable at all. I expect they simply don’t want you to see how much work is involved until after they’ve got your money. Otherwise you might be put off and not purchase.
Post #635314 23rd Jun 2022 10:42pm
RJPotts
I think you're correct there Full-fat-Lance,
I queried the "We can't release..." & asked that if it's their manual and their product then what stops them, apart from not wanting to send it. I received a reply stating;
"we are unable to release the full manual prior to purchase as we have many people trying to copy our product"
I'd be fascinated to know how anyone could copy a product such as this from some fitting instructions. Even if their instructions show hi-res photos of a single-sided circuit board all they need to do is blank out the components, apart from connectors being used, as for the purposes of the instructions you need to know only how to fit it.
There's also the point that if it were to defend against copying then all 'people trying to copy our product' need to do is buy one surely?? Reinforces my opinion that Full-fat-Lance has hit-the-nail-on-the-head.
Cheers
Post #635335 24th Jun 2022 9:56am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
because it looks like three separate units put together: universal android auto/carplay box and can bus decoder (standard chinese boxes) and lvds switching board which is the magic part, but you can buy it on aliexpress already (for L320)
Post #635380 24th Jun 2022 5:27pm
RJPotts
Tell us more jimmie....... Have you done this / seen anyone who has / got any links to successful installs or links to suitable items please? 2010 Range Rover Autobiography TDV8 Santorini Black
Post #635389 24th Jun 2022 6:15pm
jimmie
screen interface: https://www.aliexpress.com/item/1005003642...3075Yi90jJ
universal android auto / carplay box:
https://www.aliexpress.com/item/1005003307...2398%21sea
Post #635610 27th Jun 2022 9:49pm
rscsmith
Sam Motor Machine has an install video on his YouTube channel for a system provided by Unique Auto Developments. There is a follow up video where he reviews the unit after a week of use.
Install:
Review:
Post #642812 12th Sep 2022 10:12pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Yes indeed.
There is a prior thread discussing these :
https://www.fullfatrr.com/forum/topic64367.html
And another (in Group Buys) on which members are invited to register their interest in a possible forum discount :
https://www.fullfatrr.com/forum/topic64482.html 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #643044 15th Sep 2022 4:04pm
Chaps,
For information, UAD have now offered a forum discount on this product.
See thread :
Warwick 2011 L322 TDV8 A/b Orkney Grey
Post #643761 23rd Sep 2022 11:17pm
