Home > Technical (L322) > Smokey 4.4TDV8 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8620 |
I have now had this twice, once straight after collecting the car a few months back, But only once since, today!
10th Oct 2015 4:55pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
The turbo drain problem is caused by a build-up of oil over time when the secondary turbo is not regularly used. Once the oil is blown out by a good burst of secondary turbo use the smoke will not re-appear until oil has once again accumulated in the inlet tract due to lack of use of the secondary turbo. The build-up occurs because the drain is ineffective via the scavenger pump once the engine stops yet a small amount of pressurised oil is still flowing to the turbo, which then finds its way past the turbo seals which were never designed to contain oil from a drain that is effectively blocked. The revised drain has an additional direct drain to the sump so that the drain can empty with the engine no longer running. |
10th Oct 2015 8:00pm |
That's kind of how I figured it happened, sequential turbos will inevitably have the problem of under use for the secondary turbo, especially when they are driven conservatively......
10th Oct 2015 8:19pm |
albertocsoares Member Since: 28 Nov 2012 Location: Brazil Posts: 15 |
Hi guys! I have a new to me 12/13 L405 - 4.4 TDV8 with 70.000km. every time I ride the car I raise the RPM´s to 3.000 to burn the oil in the turbo, after 5.000 km of the first oil change I noticed that the oil level is going down, not much, but it is definitely going down. Do you guys see any problem in not doing the TBS service and keep adding about 1 lt of oil every 10.000 km? Thank you all. |
22nd Dec 2020 9:43pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
Doesn't sound too bad that oil usage, that's only my thought. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
23rd Dec 2020 8:46am |
That sounds a reasonable level to top up. There is nothing that can't be fixed with a hammer😜😜
23rd Dec 2020 2:39pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
10,000 km... 6,250 miles seems a good point to change the oil and filter, not top it up, to me... irrespective of manufacturers recommend service intervals. Check the oil dilution figure with your iid , and definitely change the oil if it is approaching 7.0.
23rd Dec 2020 3:51pm |
I do change the oil and filter every 10.000 km, my question was:
23rd Dec 2020 7:26pm |
No, I don’t personally think that 1L is an unreasonable top up between oil changes.
23rd Dec 2020 8:02pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Same here as northern monkey Jones Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd Dec 2020 9:47pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
Same as these 2 ^ 2012 Vogue 4.4 TDV8 - Current
23rd Dec 2020 10:00pm |
