![]() | Home > In Car Electronics (L322) > 2010MY Aftermarket Speaker Upgrade Focal ES165K2 |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
The Problem
I was really looking to repair rather than upgrade, so I was looking for similar speakers rather than how to improve the sound drastically - it just happened that the choice of 2ohm speakers was quite slim and these worked out well.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Great write up 👍 |
MAL1721 Member Since: 23 Oct 2020 Location: Hampshire Posts: 1 ![]() ![]() |
Great write up, we used to supply Focal speakers for the home setup and all speakers require matching with head units, the source. B&W are also a great choice and worth a mention if you are doing upgrades, do the speaker cables where ever possible too, why put expensive kit in and connect it with cheap cable, you lose so much quality through interconnects and cheap cabling. |
Cabling doesn’t have to be expensive to be good. It just need to be the right cabling for this distance |
Thanks for the feedback, as I say I am not an expert so very happy to get advice!
Actually, there is nothing wrong with well-crimped spade connectors either, the internet is dedicated to that topic as well. The car I rebuild had some horrid soldered splices causing 'gremlins' due to fatigue in the stress points. Something that is totally avoidable with a well-crimped connection.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
Just discovered a new type of connector.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
i have been using them a little while now they are bloody grat and a very strong joint too 2012 Vogue 4.4 TDV8 - Current
This might be the slowest follow-up to a post ever, but as I recently got a bit more serious about my audio tweaking and got myself a calibrated mic, this is what the RR looks like when tested with a calibrated microphone after the Focal speaker enhancements.
