![]() | Home > In Car Electronics (L322) > 2010MY Aftermarket Speaker Upgrade Focal ES165K2 |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
The Problem
![]() 17. Assembly is the reverse of removal pretty much. Be careful when pushing the housing for the tweeters back into place - don't push on the grill as it will bend, make sure you push around the edges! Result I'm not an audiophile, but it sounds great. You can push the highs and bass much higher in the equaliser without it starting to sound harsh. There's more detail; cymbals, high-hats etc are easier on the ears. The bass feels more punchy, you find yourself turning the volume up an extra notch. I was a bit meh about spending so much on audio equipment when the original isn't too bad, but I've no regrets with this, it's a decent upgrade! Hope this helps someone ![]() Last edited by Siftah on 18th Dec 2020 1:42pm. Edited 2 times in total |
I was really looking to repair rather than upgrade, so I was looking for similar speakers rather than how to improve the sound drastically - it just happened that the choice of 2ohm speakers was quite slim and these worked out well.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Great write up 👍 |
MAL1721 Member Since: 23 Oct 2020 Location: Hampshire Posts: 1 ![]() ![]() |
Great write up, we used to supply Focal speakers for the home setup and all speakers require matching with head units, the source. B&W are also a great choice and worth a mention if you are doing upgrades, do the speaker cables where ever possible too, why put expensive kit in and connect it with cheap cable, you lose so much quality through interconnects and cheap cabling. |
Cabling doesn’t have to be expensive to be good. It just need to be the right cabling for this distance |
Thanks for the feedback, as I say I am not an expert so very happy to get advice!
Actually, there is nothing wrong with well-crimped spade connectors either, the internet is dedicated to that topic as well. The car I rebuild had some horrid soldered splices causing 'gremlins' due to fatigue in the stress points. Something that is totally avoidable with a well-crimped connection.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Just discovered a new type of connector.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
i have been using them a little while now they are bloody grat and a very strong joint too 2012 Vogue 4.4 TDV8 - Current
This might be the slowest follow-up to a post ever, but as I recently got a bit more serious about my audio tweaking and got myself a calibrated mic, this is what the RR looks like when tested with a calibrated microphone after the Focal speaker enhancements.
