Home > In Car Electronics (L322) > 2010MY Aftermarket Speaker Upgrade Focal ES165K2 |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 |
The Problem
17th Dec 2020 5:30pm |
I was really looking to repair rather than upgrade, so I was looking for similar speakers rather than how to improve the sound drastically - it just happened that the choice of 2ohm speakers was quite slim and these worked out well.
17th Dec 2020 10:42pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Great write up 👍 |
17th Dec 2020 11:17pm |
MAL1721 Member Since: 23 Oct 2020 Location: Hampshire Posts: 1 |
Great write up, we used to supply Focal speakers for the home setup and all speakers require matching with head units, the source. B&W are also a great choice and worth a mention if you are doing upgrades, do the speaker cables where ever possible too, why put expensive kit in and connect it with cheap cable, you lose so much quality through interconnects and cheap cabling. |
19th Dec 2020 10:56pm |
Cabling doesn’t have to be expensive to be good. It just need to be the right cabling for this distance |
19th Dec 2020 11:57pm |
Thanks for the feedback, as I say I am not an expert so very happy to get advice!
20th Dec 2020 2:12am |
Actually, there is nothing wrong with well-crimped spade connectors either, the internet is dedicated to that topic as well. The car I rebuild had some horrid soldered splices causing 'gremlins' due to fatigue in the stress points. Something that is totally avoidable with a well-crimped connection.
20th Dec 2020 8:57am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Just discovered a new type of connector.
21st Dec 2020 4:00pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i have been using them a little while now they are bloody grat and a very strong joint too 2012 Vogue 4.4 TDV8 - Current
21st Dec 2020 4:16pm |
This might be the slowest follow-up to a post ever, but as I recently got a bit more serious about my audio tweaking and got myself a calibrated mic, this is what the RR looks like when tested with a calibrated microphone after the Focal speaker enhancements.
2nd Aug 2024 5:11pm |
