Home > Technical (L322) > Reduced Engine Performance...AGAIN!!! |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 682 |
That's good news, I was going to make a comment on your battery photo as I couldn't see a brand name, but thought you've enough $hi*e going on without me chipping in!
15th Dec 2020 8:44am |
Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 240 |
Oh yes that battery taken off is no brand or pavilion. It might ne OK just tested and its 13.5v so will leave it a day and retest seeif it has held the charge.
15th Dec 2020 10:18am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2458 |
The old battery was leaking suggesting that it is well past its useful life, unable to accept proper charge. Just because it may hold voltage while not in use doesn't mean that it is charged. |
15th Dec 2020 10:48am |
It is now only going to be used as a spare so can chuck it in the shed and if I ever need it I have a backup. New one should be good and 4 year warranty which will last longer than the car at this rate!!! Current Cars
15th Dec 2020 12:14pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1202 |
On the label on your old battery, there looks like a burn mark where your positive lead crosses the top of the battery. Worth checking if the cable is okay? |
15th Dec 2020 12:49pm |
Parallel Member Since: 15 Nov 2018 Location: Essex Posts: 35 |
http://www.partinfo.co.uk/files/COTB0019%2...ailure.pdf
15th Dec 2020 1:17pm |
Nice one. Apart from the error codes as I am not getting those it does seem to be similar to what is happening to mine. so it is just a matter of flipping the wires over which is simple enough.
15th Dec 2020 2:12pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
glad the battery helped.
15th Dec 2020 7:09pm |
Codes are missfires. Historically it has been bank 1 drivers side. 1,3,5,7 miss fire and as of new exhaust and battery it is 5,7 so far
15th Dec 2020 8:16pm |
sorry chap not familiar with the petrol models!!
16th Dec 2020 11:20am |
Good idea. I didn't want to buy 8 but maybe I can buy 4 for bank 1. This should cover 1,3,5,7
16th Dec 2020 12:08pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Don't buy any, just swap them and see if the problem follows the swap or stays on the same cylinders |
16th Dec 2020 12:27pm |
I dont get the error on bank 2 so could swap all 4 over and then see if bank 2 has the missfires. 2,4,6,8. If so then would point to coil packs. If errors stay on bank 1. 1,3,5,7 would point to something else. Headache but will try that. Current Cars
16th Dec 2020 12:46pm |
Camshaft sensor a possibility if misfires stays on the same bank. |
16th Dec 2020 12:52pm |
