Home > Technical (L322) > Fixed - Multiple lights and faults on the way home |
Hermes Member Since: 07 Nov 2020 Location: Oop north Posts: 108 |
Battery faulty/low voltage?
9th Dec 2020 7:59pm |
Parallel Member Since: 15 Nov 2018 Location: Essex Posts: 35 |
I'd agree with Hermes.
10th Dec 2020 11:30am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3523 |
given that, and electrics - serpentine belt? have you opened the bonnet? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
10th Dec 2020 11:36am |
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 75 |
Hi all thanks,
10th Dec 2020 1:49pm |
The belt is on but there was a squeak and a slight wobble from one of the tensioner when I started it up the other week. I was going to get it sorted when the bloke I use was back at work.
10th Dec 2020 2:00pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 719 |
Worth checking that the battery terminals are clean and tight - i've had problems with terminals working loose. |
10th Dec 2020 3:50pm |
Thanks will do.
10th Dec 2020 11:47pm |
Tool always a good investment, but if cash tight why not see if the new battery sorts your issues? |
11th Dec 2020 6:36pm |
Yep I was thinking the same thing, the smart charger has got a charge into the battery and now the fob and locks are working. The battery has been ordered not sure when it will get here.
11th Dec 2020 7:55pm |
Hi as an Update I have put a 019 in as I need the car running and the online company I had used were in Germany (even tho the website made it look like a UK company).
12th Dec 2020 5:33pm |
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 |
I've had this! It was the the belt and pulley system. If you keep driving individual systems shut down one at a time, radio, wipers dials and power steering.
12th Dec 2020 6:37pm |
Yes I did think I would be lucky if it was just then battery but it was very low. So its worth the change, I will test it tomorrow. |
12th Dec 2020 6:52pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8486 |
If it’s running slightly off the tensioner or the tensioner is wobbling then the tensioner will need replacing. It’s not a hard job, took me a couple of hours. I would say that the belt is the difficult part as it needs the VF to come off which, but unless the belt is fubar then it should be Ok.
12th Dec 2020 6:59pm |
So I have made it worse. I put the new battery in and charged it over night and if you push the start button everything lights up and all of the faults show, if you push to start the car everything goes out and doesn’t even try to start. Then it came up low power and shut down.
13th Dec 2020 12:33pm |
