Home > Technical (L322) > Fixed - Multiple lights and faults on the way home |
Mike220 Member Since: 21 Sep 2020 Location: uk Posts: 116 |
Fingers crossed for you Graham 2011 Vogue SE Tdv8 FFRR |
26th Dec 2020 5:17pm |
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 75 |
Thanks Mike, fingers crossed. |
27th Dec 2020 11:05am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8069 |
On the later L322's you really have to use the designated JLR diagnostics to locate issues, they can read to a much deeper level than any other including Snap-On etc
9th Jan 2021 2:33pm |
The garage uses Autologic, and I ran the JLR version of icarsoft. The both said the same thing. I instructed the garage to send the unit for testing as a precaution. |
9th Jan 2021 2:58pm |
The repair company has said they abs module has passed. The garage stuck it back on and the errors cam back straight away.
14th Jan 2021 2:32pm |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 |
Following, as I've been there too.
14th Jan 2021 3:23pm |
Do you think the Gap tool will tell you more than the Autologic that the garage has or the icarsoft unit I have used? I have read a load of stuff on this type of fault and it appears it could be a number of things. I had noticed before the car was collected that the steering sensor was showing a crazy angle on the icarsoft tool, I have told them this, however, like most professionals you never believe the customer.
14th Jan 2021 8:36pm |
So it’s still in the garage but the mechanic is back. They plugged the abs unit back in and the errors popped back up. They have noticed that the voltage to the fuses drops to 10v when the unit is plugged in but they show 12v when it isn’t.
27th Jan 2021 8:46pm |
So the garage has emailed, looks like a wiring fault. |
3rd Feb 2021 3:02pm |
They have fixed it there was a open short on one of the wires. They have it this out and replace it so it looks like it’s all good I should get the car back today. |
4th Feb 2021 3:44pm |
Glad it's fixed, do you know how/wire the wire was damaged and shorted and where it was..? Pete
4th Feb 2021 4:23pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
one of the wires on the connector for the ABS module?
4th Feb 2021 6:26pm |
To be honest I’m not actually sure which wire, I have a lot on and those things have been a higher priority in my life.
4th Feb 2021 7:57pm |
So the brakes definitely have air in them. The garage replied that the feed and Earth wire from main fuse box to ECU that had repair.
10th Feb 2021 4:14pm |
