Home > Technical (L405) > Battery Conditioner - Where to connect
Six-cylinder
2016 Range Rover Vogue TDV6 Loire Blue
I have a 2016 3.0 TD6 Vogue and I use it very little the way the world is. Last night it would not operate its interior light and showed me a low battery message. It did start but my journey was only 3 miles so I guess it would be good to give it a trickle charge.
I have a CTEK battery conditioner can I connect to the jump post under the bonnet or do I have to empty the boot, remove the spare wheel and connect direct to the battery?
Post #575723 11th Dec 2020 9:04am
Jump post is fine sir Thumbs Up
Post #575725 11th Dec 2020 9:06am
RRVSE-2
United Kingdom 2017 Range Rover Vogue SE SDV8 Balmoral Blue
If you have towbar electrics you can buy an adapter to charge through there. Keith
Main car : FFRR L405 Vogue SE SDV8 Balmoral Blue
Main M/C : Ducati Multistrada 1200S
Other
Suzuki Jimny
Past Cars
Ford Fiesta Titanium
D4 Nara Bronze HSE
D3 Teal S
Post #575728 11th Dec 2020 9:21am
knwatkins
As above, the posts under the bonnet are fine to use. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #575747 11th Dec 2020 3:27pm
Six-cylinder
Thanks All it is now on charge.
Post #575809 12th Dec 2020 10:17am
If you can be bothered, you can connect hard wire a CTEK connector to the posts
https://www.fullfatrr.com/forum/topic48040...p;start=15
Post #575839 12th Dec 2020 3:38pm
Gr4h4m
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
all those leaves are stressing me out.
Post #575857 12th Dec 2020 5:18pm
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Used an extra long cable on mine comes out top of the bonnet by the windscreen so i can connect my c-tek without opening the bonnet Thumbs Up 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #575879 12th Dec 2020 7:38pm
goddo
I have a Cetek charger with adapter cable so I permanently connected the adapter straight to the battery. Then all I have to do is connect the charger which can sit on top of the spare wheel while topping up.
Post #576230 15th Dec 2020 10:38am
Boatmechanic
Sweden
Service manual says that you should not connect to battery. Connect to posts in engine compartment.
Post #589271 27th Mar 2021 7:46pm
goddo
I hear what you say.
Can someone explain why there should be a problem with direct connection to the battery?
If there is a problem, I would like to be aware so that I don't cause damage to other parts in the future.
When I had a Bentley Continental GT the dealership connected me up the same way?
Post #589274 27th Mar 2021 7:59pm
Not sure it's a problem as such - but the posts are conveniently located under the bonnet.
The battery is located underneath the spare wheel....
Post #589278 27th Mar 2021 8:14pm
Historian
You can as long as you connect the negative terminal to earth rather than the negative battery terminal. There's an electronic gismo in the negative wiring that monitors battery status- if you connect Ctek directly to both battery terminals it bypasses this and the BMS thinks that the battery hasn't received the charge and various 'low-battery' strategies/warnings can be kicked off as a result.
Post #589282 27th Mar 2021 8:38pm
Very strange! I have a JLR CTEK kit and guess where it connects Whistle Whistle Whistle You guessed it, in the boot on the main battery terminals... There is a small cigar lighter charger port in the RHS boot panel... Thumbs Up
Post #589311 27th Mar 2021 11:36pm
palli
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
I to have a JLR CTEC fitted in the boot to the battery. Never had any issues. 2008 Vogue Black - gone
2012 Vogue SE White - gone
2016 Autobiography Blue - gone
2019 Autobiography Grey - gone
2020 SVAutobiography Red
Post #589322 28th Mar 2021 8:58am
