![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
Thanks, that was exactly what I done in the end |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 499 ![]() ![]() |
I'd like to know exactly the same question re. CVD voltages, not sure it's there, but would be good to know and interesting to plot against lateral G's to see the values increase on one side when cornering.
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Flat cornering? Really? Mine corners like a drunken whale!
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 ![]() ![]() ![]() |
Same here, corners flat but it bounces all over the show on really bumpy bits (more so than our Alfa 147 on it's 10 year old shocks!). Probably just because it's higher and weighs so much.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Does anyone know how to avoid ‘error E05’ when resetting engine adaptations on a 3.6 TDV8 2008 with a iID BT?
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
The EDC recalibration function on the tool seems to be hit and miss. Makes little difference to mine after a few miles
Yeah, it's really quite impressive compared to the older V8 FF we have with regular struts (which are new). She corners great for a 2.5T vehicle. It's just the ride of the 2011 TDV8 is a bit rough over potholes which the older one smooths out far, far better, although it's on 19" rims and 60 profile rubber which probably helps a lot. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
SilverSpanner Member Since: 28 Jun 2017 Location: Hamilton, South Lanarkshire Posts: 17 ![]() ![]() ![]() |
Hello everyone. I wonder if the technicians at GAP or those with superior knowledge on here can tell me if it is possible to upload an engine remap file to the engine control ECU? 2012, FFRR Westminster TDV8 - Orkney Grey
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8444 ![]() ![]() ![]() |
You can buy a remap through Gap, don't think you can use your own though... |
I've bought all the bits to create a simple logger that'll log long & lat G forces as well as amps to 2 dampers at a time, once I've written the code it'll log to an SD card all being well. Just need a rainy day to get it done. Watch this space. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2597 ![]() ![]() |
Gap advised me some months ago that their tool could not at the time update the 4.4's PCM via the OBD port. |
I would check that the 3 accelerometers are tight in their mounts. |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 ![]() ![]() ![]() |
Just activated the DRL's on my '09 USA spec FF with my IID tool. When activating I had a choice of "Main" or "dip." Does that mean here in the USA high beams Vs. low beams or something else? I have it on "dip" right now.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I shouldn't have been playing around with things, but for the life of me I can no longer figure out the combination of settings for my MY2010+ 5.0SC Autobiography. These were working but I've been messing about |
