![]() | Home > Maintenance & Mods (L322) > L322 3.6TDV8 Rear Brake Callipers Sticking |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1266 ![]() ![]() ![]() |
Did you use copper grease when installing it. I know it's been used for years but you shouldn't use it on the caliper slides. Search for brake caliper grease and you'll find a set of three greases for different parts of the installation. |
Tg87 Member Since: 09 May 2019 Location: Suffolk Posts: 21 ![]() ![]() |
Hmm I actually can’t remember if I used copper or a high temp grease. I think it may have been copper. Is this likely to do it? |
If you do use copper grease it really should only go on the back of the pads to help stop squealing. The slides usually have a rubber type grease. Copper grease is to sticky. |
Rightio I’ll give them a clean off and start again this weekend. I think it may have actually been the parking brake. I’ve applied it and reapplied a few times and it seems to have sorted it. Just seems odd because the heat seemed to be coming from the outer of the disk not the hub. When I took the wheel off I could hear the shoes rubbing. It all turns freely now so fingers crossed! |
Ok, did some investigation. Jacked it up and it sounded like the handbrake was dragging on the discs. I used the handbrake and centred the pads. It seemed to be fine. A week later it’s the same issue again.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Make sure you take off and clean/wire brush/file back the rust off the caliper carriers where the pads sit in the anti rattle springs. This is important as the carriers can corrode and grip the pads, and aren’t normally changed along with the calipers.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 490 ![]() ![]() |
Agreed - I definitely wouldn't put copper eaze on the caliper slide pins, I'd think it would degrade the rubber. I use red brake rubber grease if they need anything on the slide pins and ceramic brake grease on the back of the pads and where they contact the caliper. Having said that, there is strong evidence to say that modern pads with in-built shims don't need any brake grease on the back of them. I've seen video's by professionals on YouTube where they recommend using copper eaze on the caliper slide pins - but would personally disagree with that, as I'm certain that "copper slip/ease/eaze/grease" is mineral based and just like oil or normal grease will degrade the rubbers with time that the slide pins fit snugly into. Example at around 7mins (WRONG in my opinion) - https://rimmerbros.com/c/Replacing-the-rea...Rover-L322 Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
I've had a rear brake backing plate corrode which has led to the shoe retaining pin falling into the drum of the rear handbrake causing a brake binding / scraping noise. You might want to make sure nothings got into the drum or anything has broken loose in addition to centering the brakes and re-adjusting. Also drive slowly for 50 metres or so with the handbrake on to clear any corrosion build up that might have occured if you don't use the PB very much. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
