Home > Technical (L322) > Baffling starting problem |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 738 |
Easy things first - battery terminals clean and tight? I’ve had to use a bit of copper between the clamp and terminal to get a sound connection |
21st Nov 2020 1:49pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Earthing problem or as above power connection problem. Try a good clean of the terminals first as it’s quick, easy and free. There is nothing that can't be fixed with a hammer😜😜
21st Nov 2020 2:27pm |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
Thanks for your replies. Aside from the 2 cables from the battery, what others are there and where are they located? , I'm thinking body earth straps as one example. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
22nd Nov 2020 5:15pm |
