Home > Technical (L322) > Improve FBH 2011 |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Does the heater ramp up after it's started, does become quite a roar if running correctly. If you look underneath (nearside front) you should see it's exhaust which should be hot enough for your skin to stick to it if it's running at full power. If you're not getting warm air inside, check that the electric water pump is running, if it isn't the water in the heater gets hot, doesn't go anywhere and the heater shuts down because the water is hot. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
8th Nov 2020 6:49pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
Sounds about right.
9th Nov 2020 9:29am |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
With the timer set on mine it works completely randomly, with full tank or only say a third, makes no diff , one morning it's on, another it just doesn't switch on?? Baffling! 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
16th Nov 2020 11:01pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
I'm suspicious that my changeover valve isn't isolating the matrix which is why mine doesn't get very warm. It defrosts the windscreen, but really doesn't warm the interior much.
17th Nov 2020 9:26am |
That’s all mine does to be fair. It doesn’t run for that long, so it’s not going to be As warm as like When the engine is running. 2011 Range Rover Vogue SE 4.4 TDV8
17th Nov 2020 9:43am |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
I had the opposite a few months ago. The o ring in the valve was swollen so didn't allow engine coolant into the system. |
17th Nov 2020 9:51am |
