![]() | Home > Technical (L322) > Improve FBH 2011 |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
My 2011 came with remote FBH. All seems to work as expected. But never seems to be warm. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
I'm convinced that turning the temperature dials up to max the night before makes a difference...
Tried that. Still not even slightly warm. |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
Hi, the fan will blow warm air into the cab if the outside temp is 16 degrees or less, if the temp is above 16 the hvac will blow cold air into the interior to cool it down, if the temp outside is less than 6 degrees it will blow warm air into the interior and pump warm water around the engine block to aid cold starting. I'm with Dr Rob and think it works better if the dials are turned up, remember it will take upto 20 minutes to fully heat the interior. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
If the weather is hot, it just blows the outside air in, rather than cold, so at least the interior isn’t any hotter than outside.
flexfly Member Since: 24 May 2017 Location: Hampshire Posts: 16 ![]() ![]() ![]() |
Same in my 2012. But my old 07 got properly warm. Still defrosts the car so not complaining, it’s just not toasty warm like I expected 2012 RR Westminster TDV8 2008 Audi S5 4.2 V8 2006 Mazda MX-5 R/C Sport 2.0 Gone... 2007 RR Vogue SE 3.6 TDV8 2005 Ford Focus LX tdci 90 2006 Mazda RX-8 1996 Land Rover Discovery 300tdi 1998 BMW 523i ... |
How long should it run for at a time? I tried it this morning as the temp was less than 6 degrees.
My first was a 1952 80" Land Rover that I rebuilt myself. No heater and massive gaps around doors and windscreen. No draughts is enough for me |
This is true. But its quite a kit to have fitted if it doesn't even do anything. |
I think the one on my TD6 run for 30 mins, but I’ve a feeling it’s 20 mins on the 4.4 TDV8.
I tried to find manual but drew blank. |
Perfect, thanks.
Mine doesn’t get that warm to be fair. And I assume it would defrost the windows, but my car is inside, so I’ve never tested it for that.
