Home > Technical (L322) > Rear brake hose help
Jack last
United Kingdom 2005 Range Rover Vogue Td6 Zermatt Silver
Hi all need some help I ordered 2 rear brake hose/flexi’s and they are too long in length where they go into the caliper
been told by the supplier older ones were superseded and these will fit I’ve added pics so if these seem ok I’ll attempt again to fit td6 2006 model
Cheers
Post #570719 23rd Oct 2020 11:19am
Check your Chassis Number (up to 5A999999) - from research it looks like you have the 06 onwards pipes which appear to be longer. You may be an '06 reg but the first chassis set....
They do appear to be too long for your car...
https://www.island-4x4.co.uk/range-rover-l...4_145.html
This:
utter Censored IMHO .
Post #570728 23rd Oct 2020 12:45pm
Jack last
Hi Joe thanks only thing is the supplier is saying these will fit but it’s too long and needs jammed into position not safe for me as near the driveshaft boot
Looks like britparts uk have a shorter one 2002-2005 but already spent just over £50 for these 2 and the supplier says they will fit as superseded the older ones
My chassis no starts with 6xxxx but these are too long
Post #570731 23rd Oct 2020 12:49pm
kbald
Give the site sponsor advanced factors a call I'm sure they can help answer the questions. Current 2007 TDV8 Vogue Buckingham Blue
Post #570923 25th Oct 2020 7:30pm
