![]() | Home > My Range Rover > New purchase 2011 autobiography |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Classic Matt Member Since: 05 Sep 2020 Location: West Sussex Posts: 72 ![]() ![]() |
How bad of a job did you find replacing the oil cooler gaskets?
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 ![]() ![]() ![]() |
Fairly straightforward job as been mentioned in the wiki the top coolant hose there's a 4 way coupler best to remove it out-of the way before removing the main intake hose to the throttle body |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8689 ![]() ![]() ![]() |
Be very careful that you don’t drop anything into the oilways or let the oil and the water mix....
A scary thought! I shall tie the job in with an oil change afterwards to minimise the chance of any issues. |
Today was rear arches and sills.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
Cover arch lips with grease then fit Freelander 2 rubber arch protectors. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Will do Rob cheers, I've all ready wax oiled the lips but once that's dried a little more I'll get some grease on and will order a set of free lander 2 lip protectors now. |
Is it these ones Rob Genuine https://www.ebay.co.uk/itm/GENUINE-LANDROV...SwgQ9Vwexk Aftermarket https://www.ebay.co.uk/itm/LAND-ROVER-FREE...SwZcxdnygH |
https://www.ebay.co.uk/itm/303631687693
Thank you Rob just ordered |
Trim to fit Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Picked the wheels up after refurbishment looking forward to getting them fitted
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1208 ![]() ![]() ![]() |
Pete, can you let me know where you got the silicone hose from?
