Home > My Range Rover > New purchase 2011 autobiography |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Welcome sir... Love the work |
30th Sep 2020 11:52pm |
Classic Matt Member Since: 05 Sep 2020 Location: West Sussex Posts: 72 |
How bad of a job did you find replacing the oil cooler gaskets?
4th Oct 2020 2:21pm |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 |
Fairly straightforward job as been mentioned in the wiki the top coolant hose there's a 4 way coupler best to remove it out-of the way before removing the main intake hose to the throttle body |
4th Oct 2020 2:42pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8626 |
Be very careful that you don’t drop anything into the oilways or let the oil and the water mix....
4th Oct 2020 2:49pm |
A scary thought! I shall tie the job in with an oil change afterwards to minimise the chance of any issues. |
4th Oct 2020 3:28pm |
Today was rear arches and sills.
24th Oct 2020 8:37pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Cover arch lips with grease then fit Freelander 2 rubber arch protectors. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th Oct 2020 9:14pm |
Will do Rob cheers, I've all ready wax oiled the lips but once that's dried a little more I'll get some grease on and will order a set of free lander 2 lip protectors now. |
24th Oct 2020 9:20pm |
Is it these ones Rob Genuine https://www.ebay.co.uk/itm/GENUINE-LANDROV...SwgQ9Vwexk Aftermarket https://www.ebay.co.uk/itm/LAND-ROVER-FREE...SwZcxdnygH |
24th Oct 2020 9:23pm |
https://www.ebay.co.uk/itm/303631687693
25th Oct 2020 8:10am |
Thank you Rob just ordered |
25th Oct 2020 3:07pm |
Trim to fit Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Oct 2020 3:43pm |
Picked the wheels up after refurbishment looking forward to getting them fitted
14th Feb 2021 11:28pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1192 |
Pete, can you let me know where you got the silicone hose from?
15th Feb 2021 12:20pm |
