![]() | Home > Maintenance & Mods (L322) > Front and rear brake pads and discs |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
4 Hours!! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8672 ![]() ![]() ![]() |
Yep I agree with the above. With a 2 post lift and a big box of tools, 1/2 hour ish a corner for the fronts, a little longer for the rears as you need to fiddle with the handbrake and reset it.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2587 ![]() ![]() |
Who do you use up there? |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
I think I have the 6 POT fronts and I called JLR, got the part numbers then ordered direct from ECP using the Brembo website. I supplied to the local garage with and they have been utter ![]() I got 42k out the previous set when I got the car, and ok they were on their last legs but I was super impressed they did that much. all smug in my new plug! 2021 Westminster Black D300 2013 Vogue SE - gone Some Porsche Cayenne guff pretending to be a 4x4!! 2006 Vogue 2004 Vogue 2001 Vogue |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
If I were not already a safety related "snob" then there have been enough posts already about the quality of parts from a certain supplier to put you off anyway.
Cumbria Landrover in Penrith, have used them for years and they are the best garage / mechanics I've ever met! ![]() ![]() ![]() |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Is that Braithwaites? 2011 TDV8 Vogue SE |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 ![]() ![]() ![]() |
I have ordered all my parts from Island 4x4 in Maidstone as they are nearest to me and had free delivery. I have previously used Britpart before without any issues and they come with 24 months warranty. So I have bought Britpart grooved and drilled discs and pad wear sensors, Brembo pads for front and Delphi pads for rear. Also bought some copper grease and a rear RH calliper as the slide pin has seized on that one - this might not need replacing. Have a trip to Cornwall next week to try them out....! |
Ceramic Silverhook SGPG70 or zinc grease like Permtex is better performing and less problematic with reacting to aluminum and causing galling. Copper slip anti seize is a bit ‘old hat’ now. |
No, Braithwaites is in Newbiggin just outside Penrith. Cumbria Landrover are on Gilwilly Ind. Estate in Penrith. |
Noted! |
MAF260 Member Since: 02 Mar 2017 Location: Hertfordshire Posts: 25 ![]() ![]() |
£60 +VAT labout for all four corners? Wow, that's incredible value |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 920 ![]() ![]() |
My new Delphi pads turned up this afternoon so I had a spare hour and swopped out the padgid ones from ECP.
