Home > Maintenance & Mods (L322) > Front and rear brake pads and discs |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
4 Hours!!
19th Oct 2020 7:59pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8608 |
Yep I agree with the above. With a 2 post lift and a big box of tools, 1/2 hour ish a corner for the fronts, a little longer for the rears as you need to fiddle with the handbrake and reset it.
19th Oct 2020 8:27pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2574 |
Who do you use up there? |
19th Oct 2020 9:09pm |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 |
I think I have the 6 POT fronts and I called JLR, got the part numbers then ordered direct from ECP using the Brembo website. I supplied to the local garage with and they have been utter the last 3k! I've not had more than 20k from the discs and pads on the front and the sensor light isn't on and they are awful so just changing them out now. Pretty disappointed. I got 42k out the previous set when I got the car, and ok they were on their last legs but I was super impressed they did that much. all smug in my new plug! 2021 Westminster Black D300 2013 Vogue SE - gone Some Porsche Cayenne guff pretending to be a 4x4!! 2006 Vogue 2004 Vogue 2001 Vogue |
20th Oct 2020 12:15am |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
If I were not already a safety related "snob" then there have been enough posts already about the quality of parts from a certain supplier to put you off anyway.
20th Oct 2020 10:50am |
Cumbria Landrover in Penrith, have used them for years and they are the best garage / mechanics I've ever met! |
20th Oct 2020 6:49pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
Is that Braithwaites? 2011 TDV8 Vogue SE |
21st Oct 2020 6:57am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Deleted |
21st Oct 2020 11:16am |
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 |
I have ordered all my parts from Island 4x4 in Maidstone as they are nearest to me and had free delivery. I have previously used Britpart before without any issues and they come with 24 months warranty. So I have bought Britpart grooved and drilled discs and pad wear sensors, Brembo pads for front and Delphi pads for rear. Also bought some copper grease and a rear RH calliper as the slide pin has seized on that one - this might not need replacing. Have a trip to Cornwall next week to try them out....! |
21st Oct 2020 12:10pm |
Ceramic Silverhook SGPG70 or zinc grease like Permtex is better performing and less problematic with reacting to aluminum and causing galling. Copper slip anti seize is a bit ‘old hat’ now. |
21st Oct 2020 3:42pm |
No, Braithwaites is in Newbiggin just outside Penrith. Cumbria Landrover are on Gilwilly Ind. Estate in Penrith. |
21st Oct 2020 5:58pm |
Noted! |
21st Oct 2020 6:04pm |
MAF260 Member Since: 02 Mar 2017 Location: Hertfordshire Posts: 25 |
£60 +VAT labout for all four corners? Wow, that's incredible value |
21st Oct 2020 10:37pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 901 |
My new Delphi pads turned up this afternoon so I had a spare hour and swopped out the padgid ones from ECP.
22nd Oct 2020 6:27pm |
