Home > Technical (L322) > Removing ball joint - at wits end |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
you need one of these.
18th May 2020 9:34pm |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 |
I made this tool to get the drive shaft out. It still took a lot of work to get them out!
17th Jun 2020 4:36pm |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 |
Trying to replace these arms and bottom ball joints as bushings in arms knackered. Got the arm off but stripped one of the Torx bolts on the ball joint. Tried to smash an 11/16 socket over the bolt but no joy. Going to collect a bolt extractor to see if that'll budge it. Could refit arm and leave ball joint but seems silly not to replace. Its not damaged but moves very easily when compared to new and if ball joint need doing soon I'll have to repeat half the job again. These cars are such fun!! |
20th Oct 2020 11:25am |
If you have access to a welder, place a larger nut over the ruined bolt and weld it on. The heat combined with something to hold nearly always helps in these situations. Rob 05 L322 4.2SC
20th Oct 2020 11:34am |
Not a bad idea, I've got an Arc welder in the depths of the garage. Think I'll dig it out if the extractor doesn't work.
20th Oct 2020 11:42am |
I try to avoid extractors. They almost never work, and if they fail, the hardened material is impossible to drill.
20th Oct 2020 11:44am |
Right I'll probably try to weld a nut on first then. Thanks.
20th Oct 2020 11:47am |
It's true. I normally replace as much as I can before I have tracking done. A good "Hunter" alignment can cost quite a bit of money and only doing the job once is vital when you have family, work and lots of cars/motorbikes competing for attention. Rob. 05 L322 4.2SC
20th Oct 2020 11:50am |
Well getting to the welder was not possible as it's in garage in front of MGB which I cannot move due to RR up on stands behind it! Persevered with trying to knock socket over bolt which I finally manged to make the bolt loosen enough to then wind out with screwdriver. Cup of tea time before I go back out and bray the living crap out of the ball joint to remove it! |
20th Oct 2020 2:32pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Think of it as a cathartic smashing.....
20th Oct 2020 5:17pm |
After an hour of bashing had to give in. Firstly I think the neighbours has heard enough banging (and expletives) and secondly my back was asking for a break! I'll continue tomorrow when I get chance. Back of ball joint now bashed in, also tried a punch which has made a hole in the back but no sign of either getting the back off or the ball joint moving in the slightest. Keep popping out to add more penetrating oil. |
20th Oct 2020 5:50pm |
200AD Member Since: 17 Apr 2019 Location: Leicestershire Posts: 18 |
Have you tried doing it the other way round? Removing the car from the ball joint rather than removing the joint from the car? It'll take a fair old team of us rotating the car while you hold the joint still though, so you'd have to wait a while until after Covid....... |
20th Oct 2020 6:39pm |
Probably wouldn't be more difficult than it is anyway
21st Oct 2020 10:49am |
21st Oct 2020 12:30pm |
