![]() | Home > Technical (L322) > Preparing to rebuild M62 |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3200 ![]() ![]() |
great car T!! lovely colour! Not sure what your mileage is but I had the Chain guides done at 189,000 miles (310,000KM). Its a big job (£3,000 in UK) so worth doing. The guides get brittle over time and crack when the chain slaps it, especially on start up).
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
How is this job going/gone?
kanikune Member Since: 29 Oct 2017 Location: Teerijarvi Posts: 28 ![]() ![]() ![]() |
Actually last night we fired up the rebuild and did short test drive. Everything seems to be gone perfect at the moment but still needs to see things are okay. I will return to this soon.
That good.
You need the M62tu timing tool set.
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 41 ![]() ![]() ![]() |
You need a timing kit, I have one, only used once if you are interested 2010 3.6 TDV8 |
Thanks, I have all that.
I’m not sure RAVE covers that engine?
gt40 Member Since: 29 Jan 2013 Location: Cape Town Posts: 31 ![]() ![]() ![]() |
You will find the procedure in RAVE; Engine V8; overhaul; Gasket -cylinder head. Further information on camshaft orientation in the next section - Cylinder head overhaul which leads you to Variable Camshaft Unit - variable camshaft control (VCC). |
Okay so aforementioned two Victor Reinz sets include 98% of the gaskets for the job.
Ahh that is AMAZING, thank you so much, I can only see bank 5-8 but not 1-4 though??? |
Landyandy1765 Member Since: 25 Mar 2019 Location: bournemouth Posts: 56 ![]() ![]() ![]() |
i have a vanos timing kit if anyones interested . also new thermostat housing . and a new pcv valve |
How much for the PCV? |
Hi £50. For the pcv |
