Home > Technical (L322) > Preparing to rebuild M62 |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3185 |
great car T!! lovely colour! Not sure what your mileage is but I had the Chain guides done at 189,000 miles (310,000KM). Its a big job (£3,000 in UK) so worth doing. The guides get brittle over time and crack when the chain slaps it, especially on start up).
19th Aug 2020 7:29pm |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
How is this job going/gone?
9th Oct 2020 1:54pm |
kanikune Member Since: 29 Oct 2017 Location: Teerijarvi Posts: 28 |
Actually last night we fired up the rebuild and did short test drive. Everything seems to be gone perfect at the moment but still needs to see things are okay. I will return to this soon.
11th Oct 2020 6:17am |
That good.
12th Oct 2020 3:24pm |
You need the M62tu timing tool set.
12th Oct 2020 4:18pm |
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 41 |
You need a timing kit, I have one, only used once if you are interested 2010 3.6 TDV8 |
12th Oct 2020 4:38pm |
Thanks, I have all that.
12th Oct 2020 7:32pm |
I’m not sure RAVE covers that engine?
12th Oct 2020 9:16pm |
gt40 Member Since: 29 Jan 2013 Location: Cape Town Posts: 31 |
You will find the procedure in RAVE; Engine V8; overhaul; Gasket -cylinder head. Further information on camshaft orientation in the next section - Cylinder head overhaul which leads you to Variable Camshaft Unit - variable camshaft control (VCC). |
13th Oct 2020 12:48am |
Okay so aforementioned two Victor Reinz sets include 98% of the gaskets for the job.
13th Oct 2020 12:57pm |
Ahh that is AMAZING, thank you so much, I can only see bank 5-8 but not 1-4 though??? |
13th Oct 2020 1:37pm |
Landyandy1765 Member Since: 25 Mar 2019 Location: bournemouth Posts: 56 |
i have a vanos timing kit if anyones interested . also new thermostat housing . and a new pcv valve |
18th Oct 2020 5:41pm |
How much for the PCV? |
21st Oct 2020 5:31pm |
Hi £50. For the pcv |
21st Oct 2020 6:54pm |
