![]() | Home > Technical (L322) > Black Smoke |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Pretty sure, irrespective of engine, it will be a split rubber hose. May take some finding, as some splits only obvious under load, so you will have to have a really good inspection.
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 ![]() ![]() ![]() |
I can confirm that the top intercooler hose has split Land Rover will sell only the top hose and the metal pipe and the bottom hose as a complete set for £250.
This item on eBay the one you are looking for ......111697204836 |
Thank you now ordered |
All fitted now no more smoke screen |
Brooklyn4905 Member Since: 21 Jul 2019 Location: Denny Posts: 1 ![]() ![]() ![]() |
Did this also put engine warning light and limp mode ? |
I've got an early 2004 TD6 not sure if it should have but it didn't |
