Home > Technical (L322) > Black Smoke
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Black Smoke
I have noticed of the last few days that under acceleration my car has been producing black smoke out the back, it doesn't burn any oil. I have viewed a few threads on black smoke but they seam to be for the TDV8 and I have the TD6 is it likely to be the intercooler pipes and is there anyway of testing the system to find any leaks.
Thank in advance.
Post #567302 17th Sep 2020 12:50pm
mjdronfield
Pretty sure, irrespective of engine, it will be a split rubber hose. May take some finding, as some splits only obvious under load, so you will have to have a really good inspection.
Then you can replace with a silicone hose rather than OE.
My first guess.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #567304 17th Sep 2020 12:55pm
matlandy
I can confirm that the top intercooler hose has split Land Rover will sell only the top hose and the metal pipe and the bottom hose as a complete set for £250.
Dose any body know where I can just get the top hose from.
Post #568287 28th Sep 2020 3:05pm
This item on eBay the one you are looking for ......111697204836
Post #568297 28th Sep 2020 5:30pm
matlandy
Thank you now ordered
Post #568363 29th Sep 2020 12:45pm
matlandy
All fitted now no more smoke screen
Post #568501 1st Oct 2020 1:33pm
Brooklyn4905
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
Did this also put engine warning light and limp mode ?
Post #569542 11th Oct 2020 7:31pm
matlandy
I've got an early 2004 TD6 not sure if it should have but it didn't
Post #569621 12th Oct 2020 12:54pm
