Home > Technical (L322) > 4.4 TDV8 injector codes - help please
Page 1 of 3 123>
MAF260
I'm getting fault codes for each of the injectors - Cylinder X - Injector data incomplete. All codes start with P26
Seems all injector code information has been lost from the EEPROM. I believe I'm right in thinking I can reload these codes and all should be good? If so - how do I get the codes? Do I have to start removing things from the engine bay to get to the injectors and try to read them? Would the codes be stored anywhere? Any labelling etc. under the bonnet?
Thanks in anticipation
Post #568998 5th Oct 2020 9:22pm
GGDR
What 'actual' symptoms do you have other than the codes?
Also the screen says....V3 3.6.... wondering if the code reader you are using knows it's looking at a 4.4 ?
Or is that ...3.6... just coincidental? Or is it V33 something ?
. Cheers, Greg
Post #569000 5th Oct 2020 10:23pm
MAF260
Car starts and idles fine, will drive perfectly OK until any load is applied (anything other than VERY gentle throttle) - car then shows Restricted Performance message. goes into limp mode. I found that switching cruise control on to get the car home at 50mph didn't bring up the fault.
Switch off then back on and no error messages, only when under load (accelerating gently up a hill etc.)
Also found a pending fault code P1247 - low boost pressure, which I think is linked to not having the injector codes stored.
Code reader is just coincidence, it's reading the correct model, engine etc. I think the numbers you refer to are maybe the software version/code
Post #569003 5th Oct 2020 11:11pm
GGDR
ok - coincidence on the reader.....
P1247 - low boost pressure - and you have RP under throttle.... air leak?
This is the most common fault with these engines. Luckily easy to fix though.
Search 'donut hoses'
As for your injector codes... Maybe?
Can't remember ever reading about that fault here at least.
If possible could you try reading codes with another code reader to cross-check?
Is it fuel in this case? All eight injectors seems odd.
. Cheers, Greg
Post #569005 6th Oct 2020 12:16am
GraemeS
Your diagnostic tool doesn't recognise the injectors, not that the ECM doesn't recognise the injectors.
Fix the air leak as noted above and forget about looking for white stones.
Post #569006 6th Oct 2020 4:52am
MAF260
Thanks for the replies.
I'm new to these cars - would you please clarify that I should be looking for a leak from a loose or split pipe? Where would I find the likely culprits please?
Thank you
Post #569010 6th Oct 2020 7:38am
GraemeS
A forum search on the fault code P1247 brought up this pertinent post.
https://www.fullfatrr.com/forum/topic54572.html?highlight=p1247
Post #569011 6th Oct 2020 8:14am
MAF260
Thanks very much. I'll be under the bonnet this afternoon to see what I can find.
Post #569012 6th Oct 2020 8:32am
DrRob
Start with the 4 hoses into the "doughnut" Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569013 6th Oct 2020 9:55am
MAF260
Thanks, all - seems I've found the culprit:
Next question - do I need to remove the donut completely to remove the hose? I think I may as well replace all 4 with some silicone hose. Is the bore 70mm? Anything else I need to know to complete the job?
Sorry for all the newbie questions!
Post #569017 6th Oct 2020 1:37pm
Baltic Blue
They can be replaced without removing the doughnut “plenum”, but you may wish to clean it out a bit at the same time.
The full workshop manual is freely available in the Wiki, with a full PDF describing the procedure.
Post #569020 6th Oct 2020 1:51pm
GGDR
clean as much as you can as Mike says, consider doing the throttle body too.
glad you found it. Thumbs Up
9/10 times RP on these engines is caused by air leaks. They run at quite high boost.
. Cheers, Greg
Post #569021 6th Oct 2020 2:02pm
DrRob
Forum strikes again Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569026 6th Oct 2020 2:24pm
MAF260
Thanks for all the help, it's really appreciated.
I'm just back from picking up some silicone hose and new jubilee clips. If one hose is split I'd rather do some preventative maintenance and replace all 4. Just one OEM hose costs around £35. I've just bought half a metre of Mocal hose and 8 decent quality jubilee clips for £28.82.
I shall start on the repair this evening.
Post #569043 6th Oct 2020 4:54pm
DrRob
Please keep us posted as all information is useful for future reference Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #569044 6th Oct 2020 4:59pm
Page 1 of 3 123>
