![]() | Home > Technical (L322) > 4.4 TDV8 injector codes - help please |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
What 'actual' symptoms do you have other than the codes?
MAF260 Member Since: 02 Mar 2017 Location: Hertfordshire Posts: 25 ![]() ![]() |
Car starts and idles fine, will drive perfectly OK until any load is applied (anything other than VERY gentle throttle) - car then shows Restricted Performance message. goes into limp mode. I found that switching cruise control on to get the car home at 50mph didn't bring up the fault.
ok - coincidence on the reader.....
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2642 ![]() ![]() |
Your diagnostic tool doesn't recognise the injectors, not that the ECM doesn't recognise the injectors.
Thanks for the replies.
A forum search on the fault code P1247 brought up this pertinent post.
Thanks very much. I'll be under the bonnet this afternoon to see what I can find. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Start with the 4 hoses into the "doughnut" Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Thanks, all - seems I've found the culprit:
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
They can be replaced without removing the doughnut “plenum”, but you may wish to clean it out a bit at the same time.
Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
clean as much as you can as Mike says, consider doing the throttle body too.
Forum strikes again |
Thanks for all the help, it's really appreciated.
Please keep us posted as all information is useful for future reference |
