Home > Technical (L322) > 4.4 TDV8 injector codes - help please |
MAF260 Member Since: 02 Mar 2017 Location: Hertfordshire Posts: 25 |
I managed to get an hour on the car tonight, made decent progress
6th Oct 2020 9:57pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
normally I'd say brake cleaner but if cleaning parts on the car not too sure.
6th Oct 2020 10:05pm |
Thanks, Greg.
6th Oct 2020 10:07pm |
Help please...
7th Oct 2020 6:54pm |
not done this myself and I'm sure somebody who has will be along soon...
7th Oct 2020 7:08pm |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 |
There a tab you have to push in and then pull up. |
7th Oct 2020 7:29pm |
As the top picture is now there's a green tab |
7th Oct 2020 7:31pm |
Sorry, forgot to mention the tab!
7th Oct 2020 7:45pm |
Odd thing is the workshop manual seems to suggest the whole thing can be removed from the donut without separating the pipes. Given it's a water pipe I don't know if the system will need bleeding afterwards if I do need to separate them?
7th Oct 2020 7:47pm |
It 100% separates ill see if I can find the old pipe I replaced on mine regarding bleeding no all should be fine I didn't have to bleed the system after removal. |
7th Oct 2020 8:20pm |
Just been out to work shop and got you a couple of pics
7th Oct 2020 8:35pm |
That's very kind of you, thank you.
7th Oct 2020 8:48pm |
No problem I hope the new hoses sorts your issues. |
7th Oct 2020 8:50pm |
Hoses are now replaced and everything got a major clean while it was disassembled. It's a wonder the engine runs with that much crap being recirculated back into the inlet.
9th Oct 2020 2:09pm |
