Home > Wheels & Tyres > How to secure space saver wheel
Bingo_123
Posting for my cousin
My 07 rr, running 21" style 101 wheels. So bought a space saver wheel which is 20"
Good so far, but the round/long screw doesn't hold the spacesaver fully down similarly to the full size spare.
So it's now jumping up/down when going over the bumps quite loudly.
Has anyone faced this problem?
Please suggest how to secure this spacesaver wheel.
Thanks in advance.
Post #568934 4th Oct 2020 11:06pm
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Bag of cement Thumbs Up
 2006 4.2 SC
Post #568935 4th Oct 2020 11:20pm
Put two space savers in the hole Whistle Whistle Whistle Very Happy
Post #568936 5th Oct 2020 12:16am
If it's a space saver from an L405, there is also a polystyrene piece available to put underneath it.
The irony is that it then saves no space.... Confused
Post #568942 5th Oct 2020 7:39am
or do what i did....put 3/4 pieces of off cut foam under the space saver to bring it up to "screw down" height.... ... - .- -.
Post #568943 5th Oct 2020 8:04am
dingg1
Throw away the space saver and replace with 4 tins of tyre weld and listen to their merry tune as they rattle about Laughing
Post #568947 5th Oct 2020 9:10am
Baltic Blue
Drilling a hole in a suitable off cut of wood to sandwich between the wheel and the holding down bolt seems easy to me.
Post #568949 5th Oct 2020 9:34am
from memory I'm sure the bracket is higher than the depth of the wheel Mike.. ... - .- -.
Post #568954 5th Oct 2020 9:49am
Baltic Blue
Not one of my better ideas then Rolling with laughter
Post #568957 5th Oct 2020 9:52am
Bingo_123
thanks guys for the wonderful ideas, i think this foam idea should sort this out.
thanks
Post #568972 5th Oct 2020 3:10pm
