![]() | Home > Wheels & Tyres > How to secure space saver wheel |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
Bag of cement |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Put two space savers in the hole |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
If it's a space saver from an L405, there is also a polystyrene piece available to put underneath it.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35606 ![]() ![]() |
or do what i did....put 3/4 pieces of off cut foam under the space saver to bring it up to "screw down" height.... ... - .- -.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1365 ![]() ![]() |
Throw away the space saver and replace with 4 tins of tyre weld and listen to their merry tune as they rattle about |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3811 ![]() ![]() ![]() |
Drilling a hole in a suitable off cut of wood to sandwich between the wheel and the holding down bolt seems easy to me.
from memory I'm sure the bracket is higher than the depth of the wheel Mike.. ... - .- -.
Not one of my better ideas then |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
thanks guys for the wonderful ideas, i think this foam idea should sort this out.
