Home > Technical (L322) > c1a55-01 start engine to raise vehicle
gopher_tortoise
United States 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
That sounds like a good place to start looking. According to https://www.fullfatrr.com/forum/post409983.html, the BCU is under the passenger seat for LHD 2005, so hopefully it's in the same spot on my 06. In that location, it may have been repositioned when the floor liner was replaced, so that sounds promising.
Post #568122 27th Sep 2020 10:58am
gopher_tortoise
With help from Patrick Meilleur at GAP, I got the suspension to work. It turns out that a fuse was missing -- fuse 7. This provides the ignition signal to the suspension ECU. The confusing part is that the owner's manual in the car has fuse 7 as blank -- the previous owner must have put the fuses back according to the manual when he was working on the SAS replacement.
My questions now are 1) Why is the owner's manual incorrect? Is it a replacement one that's the wrong year, or was there an error in the original? And what are the correct fuses? 2) How many other fuses did he mess with -- I have to assume all of them -- there are still a bunch of other errors on the car including TPMS, DSC and some transmission warning.
So does anyone have the correct fuse diagram for an NAS 2006 supercharged? -- I'll ask in a new thread in case someone else ever searches for this.
Post #568901 4th Oct 2020 4:58pm
Another endorsement for the fabulous customer service from Patrick @GAP Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #568920 4th Oct 2020 6:41pm
GraemeS
That little section of the wiring diagram is for MY07-09. The suspension ecu will have 4 connectors rather than 2 of the earlier suspension ecus. What is the build date of your vehicle?
I suggest that you refer to MY07-09 wiring diagrams and fuses.
Post #568932 4th Oct 2020 7:59pm
