Home > Maintenance & Mods (L322) > New owner needs tow bar help |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
have a look in our wiki re the towbar.. ... - .- -.
30th Sep 2020 4:15pm |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 171 |
I think I should have worded this better, it is the type op tow bar, i.e. are the removable ones up to the rigours of towing heavy trailers with moving occupants or are the fixed ones a better bet but not as elegant when not in use. Thanks, Will |
30th Sep 2020 5:08pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Depends what you're after really - strongest & simplest - go for the OE Westfalia unit from PF Jones.
30th Sep 2020 5:22pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
The Westphalia OE type armature and fixed farmers hitch still appears on the pfjones ebay items.
30th Sep 2020 7:34pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Forget the Wiki.
30th Sep 2020 7:43pm |
Doh - still on the main site too - unless you search for L322 & then they are left out of the results..... This is what I'd do - https://www.pfjones.co.uk/range-rover-towb...-only.html https://www.pfjones.co.uk/landrover-range-...owbar.html |
1st Oct 2020 6:42am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 540 |
For info., I've just ordered the Westfalia armature and fixed hitch from PF Jones and although on back order delivery is expected 2-4 weeks from order. Drives:
1st Oct 2020 8:13am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Yes the tow ball/bar does tend to keep the plebs well back. Motor damage (to their vehicle) if the hit it! |
3rd Oct 2020 3:14pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
3rd Oct 2020 6:05pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
If you want to tow a heavier trailer then either the farmers hitch or the detachable will do the jo perfectly well.
3rd Oct 2020 7:04pm |
10th Oct 2020 9:06pm |
ffaffage Member Since: 12 Aug 2019 Location: Hampshire Posts: 19 |
Farmers hitch is definitely the way to go, as it also gives you some height adjustment. The removable ones are always a bit worrying (there were stories a few years ago about them self-detaching through user error), and the farmers hitch lets you mount standard accessories like bike racks that bolt to the two holes - better than the ones that clamp to the ball.
18th Oct 2020 9:37am |
