Home > Maintenance & Mods (L322) > New owner needs tow bar help
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Well I have bought a 59 reg. Vogue, not an SE but it does seem to have a lot of non standard kit, heated seats, upgraded infotainment, 20” super charged wheels and 58 K of full LRSH, it has done 5 K in the last 6 years, I'll treat him to a full oil change, EGR removal etc. I have been looking for one for several years now and this one came up at the right time so there we are one proud owner of a Stornoway grey/ black interior fattie.
Now I would like to ask what the general opinion on tow bars is, I have to fit a system to tow the cattle trailer in style and comfort, have read on the forum quite a bit and the information available is mind boggeling but I struggle to find the info I need.
Any help will be greatly appreciated, Will
Post #568444 30th Sep 2020 3:49pm
have a look in our wiki re the towbar.. ... - .- -.
Post #568449 30th Sep 2020 4:15pm
Red Hot one
I think I should have worded this better, it is the type op tow bar, i.e. are the removable ones up to the rigours of towing heavy trailers with moving occupants or are the fixed ones a better bet but not as elegant when not in use. Thanks, Will
Post #568454 30th Sep 2020 5:08pm
Depends what you're after really - strongest & simplest - go for the OE Westfalia unit from PF Jones.
[EDIT] Just checked and it looks like PF Jones no longer supply the OE kit Shocked
It has an armature piece that attaches to the chassis & has a 2" square receiver (american style). Then a couple of options, but I'd say the drop (farmers) hitch is best for your application. Ultimately it's removable again, leaving just the receiver visible.
There is another option of a 'removable' unit to go into the receiver, but it leaves so much on display when reoved, I've never really seen the point....
Post #568455 30th Sep 2020 5:22pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
The Westphalia OE type armature and fixed farmers hitch still appears on the pfjones ebay items.
By coincidence I was looking earlier today & saw them - approx £430 IIRC Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #568463 30th Sep 2020 7:34pm
Brian Considine
Forget the Wiki.
My vote goes to the P F Jones kit - electrics are plug & play.
Personally, I would never use a removalable type as I simply do not trust them & in anycase, to me a RR looks undressed without a purposeful looking towbar. 2003 Range Rover Vogue TD6
Post #568464 30th Sep 2020 7:43pm
Doh - still on the main site too - unless you search for L322 & then they are left out of the results..... Embarassed
This is what I'd do -
https://www.pfjones.co.uk/range-rover-towb...-only.html
https://www.pfjones.co.uk/landrover-range-...owbar.html
Post #568475 1st Oct 2020 6:42am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
For info., I've just ordered the Westfalia armature and fixed hitch from PF Jones and although on back order delivery is expected 2-4 weeks from order. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #568483 1st Oct 2020 8:13am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Yes the tow ball/bar does tend to keep the plebs well back. Motor damage (to their vehicle) if the hit it!
Post #568796 3rd Oct 2020 3:14pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
I have the above Items on my fatty, "secondary parking sensor" Smile .
Post #568818 3rd Oct 2020 6:05pm
If you want to tow a heavier trailer then either the farmers hitch or the detachable will do the jo perfectly well.
I’ve towed my full 3.5t Indespension trailer with my 322 with a detachable westfalia bar. No problems.
You will need:
The armature which bolts to the car this part is multi purpose and will take either the farmers drop hitch or the detachable, these both fit into the 2” recieved hole on the armature.
Then you need either the drop plate farmers, which is technically removable pretty easily or the detachable unit which is what it says on the packet.....
Plus some electrics. The dedicated LR wiring wasn’t too expensive from the dealer from what I can remember.... There is nothing that can't be fixed with a hammer😜😜
Post #568824 3rd Oct 2020 7:04pm
Red Hot one
Well, I have installed a tow bar, PF Jones supplied a PTC Flange tow bar, RV4216A, fitted perfectly and the wiring loom worked first time, I did manage to order the wrong 2009 loom first but they were very accommodating in sending the correct one. The OH did have a bit of a fit when she saw the back half of the FF in bits on the shelf but has now calmed down. Thanks for the suggestions especially suggesting PF Jones.
Will
Post #569440 10th Oct 2020 9:06pm
ffaffage
Farmers hitch is definitely the way to go, as it also gives you some height adjustment. The removable ones are always a bit worrying (there were stories a few years ago about them self-detaching through user error), and the farmers hitch lets you mount standard accessories like bike racks that bolt to the two holes - better than the ones that clamp to the ball.
As it's a 2 inch receiver you can use US style bike racks too, though you need to watch for how recessed the hitch is - I had to modify my thule so it didn't foul the bumper. It did only cost me 99p on ebay as few people in the UK have a 2 inch receiver, so I wasn't too worried if it didn't work out Smile
For the properly agricultural look change the ball for a ball and pin hitch.
One of my trailers uses a ring hitch so I needed this anyway, but it's also a useful way of attaching tow straps for recovery.
Post #570202 18th Oct 2020 9:37am
