Home > Technical (L322) > Venture cam cradle voltage |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6730 |
Mine doesn't seem to work at all. According to the manual the rubber power button should have a glow around it when it's charging, but mine stays dark! Got - 2017 SDV8 Autobiography in Loire Blue
26th Mar 2011 7:47pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Can anyone help please? Previously..
28th Mar 2011 7:30pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
are you sure the cam is sitting correct in the holder and the pins are making contact, if you have metered it out you will know what contact is 12v+ and negative you could do as i did to test my cam and that was used a 12v 500ma adapter and put the wires on the correct terminals it will charge it, i would say even if you was getting a 12v for a few seconds then of and on it would put some charge in to it so my guess it not making contact.. V8 facelift Range Rover Autobiography 22" wheels.
28th Mar 2011 7:49pm |
Thanks daveo..
29th Mar 2011 4:38pm |
Hi just tried it on my cam, the green oval only comes on when you pushed the button once it will flash as it looks for a connection, push the button again and the torch will come on...when charging the green oval does not come on... you can have bad luck on 3 units, connect the 12v supply and wait a while as it may be dead flat..just make sure you have the + and - on the right way...
29th Mar 2011 8:00pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Not a big help but when I did my Landrover offload day in the new FFRR the guide had trouble with the venture can as it had been put in the holder/charger the wrong way. So it is possible to do so could cause an issue. Not much help but might help. |
29th Mar 2011 8:14pm |
I've had the venture cam on a 12v charger for 24hours. It's completely dead.
30th Mar 2011 8:51pm |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 |
I have tryed charging the venture cams with an external charger and they dont work . Even made a base with pins to sit it on
31st Mar 2011 2:07pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35360 |
done this for you, the voltage goes from 13.6 to 12.2 to 7/8 volts..these voltages change slightly but still read 13-12-7 point something [does that make sense?]... try a charger with alternating current like a radio charger rather than direct as in a battery charger.. ... - .- -. Y. O. L. O. . |
31st Mar 2011 2:29pm |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
I wonder if the cam has been left in the charger and never used it and the rechargable battery is passed it's sell-by date or has had too many cycles without being discharged
31st Mar 2011 2:54pm |
hi, dont try to open it, it sealed and you will kill it for sure, did you get my pm, te offer is there if you want it.
31st Mar 2011 5:05pm |
Thank you very much guys for taking the time.... Scarey, that's great, my cradle is probably ok then as it does the same.
31st Mar 2011 10:11pm |
Just had my first play with a venture cam.
14th Apr 2011 8:33am |
thats good news dave, now you need to find a use for it. ... - .- -.
14th Apr 2011 9:20am |
