![]() | Home > In Car Electronics (L322) > Anyone fitted amateur radio gear in an L322? |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
Here are a few pics of my DIY attempt. I have a 80 channel uhf Oricom unit, tiny, not much bigger than a pack of cards with controls on the Mic. The Mic lives between the console and seat but when in use on the clip. The clip just pushes between the dash vent so no holes if removed. I made the aerial bracket, it looks quite flimsy but is in fact rock solid, I put a small piece of rubber on the bonnet lip which pushes down when closed. The grill can easily be removed. I ran the Aerial cable through the grommet behind the battery.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1547 ![]() ![]() |
Thanks Wayne. More grist for the mill. Ron B. VK2OTC
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
Cobber I will take a punt here and say I doubt that they are available commercially.
Blade74 Member Since: 30 Apr 2015 Location: Sydney Posts: 55 ![]() ![]() |
Thanks Ziggy,
Marky72 Member Since: 07 Sep 2020 Location: Somerset Posts: 1 ![]() ![]() ![]() |
Can i ask where I can get these brackets please
As mentioned before, you will need to fabricate one yourself. 2007 TDV8 VSE
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 ![]() ![]() ![]() |
Throwing another idea into the pot...
Came across this and thought I'd add to the thread;
I've installed a QYT KT-8900 on the top of the dash with double-sided tape. The 2m/70cm Diamond NR-770H whip antenna is on a bracket (previously used for my UHF CB) jutting out through the grille.
