Home > In Car Electronics (L322) > Anyone fitted amateur radio gear in an L322?
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Here are a few pics of my DIY attempt. I have a 80 channel uhf Oricom unit, tiny, not much bigger than a pack of cards with controls on the Mic. The Mic lives between the console and seat but when in use on the clip. The clip just pushes between the dash vent so no holes if removed. I made the aerial bracket, it looks quite flimsy but is in fact rock solid, I put a small piece of rubber on the bonnet lip which pushes down when closed. The grill can easily be removed. I ran the Aerial cable through the grommet behind the battery.
After a bit of use I am very happy with the usability in the selected location
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #366460 11th Jan 2016 4:13am
p38arover
Australia
Thanks Wayne. More grist for the mill. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #366462 11th Jan 2016 5:29am
Blade74
Australia
I'm currently looking at mounting an Icom IC450 and would love to find a bonnet bracket like the ones in this thread does anyone have anywhere any to sell or somewhere I can get one?
Cheers
Post #367291 16th Jan 2016 3:28am
Ziggy
Australia
Cobber I will take a punt here and say I doubt that they are available commercially.
There are very few bits for the FF on the after-sales market.
But if you have a hammer, drill, angle grinder and a vice its easy to fab up yourself
take you about hour an half from start to bolted on the car all painted up.
Or alternatively take a copy of the one you like off here pop into your local engineering
shop and ask them to fab one up for you.
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #367881 18th Jan 2016 10:34pm
Blade74
Australia
Thanks Ziggy,
Yeah unfortunately apartment living doesn't allow me the footwork shop I'd love to have.
I have a fair few tools but not as easy.
Just thought someone might have made a few.
Would be cool to get a few made up for other owners.
Post #367900 19th Jan 2016 2:41am
Marky72
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Can i ask where I can get these brackets please
Ziggy wrote:
Couple of photos of the aerial mount using existing holes just increased the bolt length by 5mm
The radio you can just see the big bolt (existing) that the bracket is bolted to then the radio's bolted on the bracket
power comes from the cig lighter in the center console It can all be removed leaving no trace of it ever having a UHF fitted
Hope it helps
Zigg
Post #566568 7th Sep 2020 11:35pm
wayneg
As mentioned before, you will need to fabricate one yourself. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #566569 7th Sep 2020 11:55pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Throwing another idea into the pot...
The existing "shark fin" on the roof which houses the GPS antenna for the SatNav looks fairly easy to remove. There's wiring holes there which route down into the rear boot space where all the fuse boxes are.
I don't do CB or Ham stuff but I've an interest in electronics and have longer term intentions to have the car fitted with a small PC (raspberry pi) to do RF stuff; mostly LoraWan and related 868mhz/433mhz stuff for triggering gate controls etc.
I'm planning on 3d printing a new "shark fin" for the antennas to be mounted - sprayed up in the right colour it should look OEM and mean I can return everything to stock if it doesn't work/I get bored/sell the car etc Smile
Post #568317 28th Sep 2020 8:13pm
Siftah
Came across this and thought I'd add to the thread;
https://www.landroverpassion.com/en/produc...over-l322/
And if you have the FrontRunner roof rack there's also this option:
https://www.frontrunneroutfitters.com/en/d...mount.html
Post #655193 30th Jan 2023 8:19pm
p38arover
Australia
I've installed a QYT KT-8900 on the top of the dash with double-sided tape. The 2m/70cm Diamond NR-770H whip antenna is on a bracket (previously used for my UHF CB) jutting out through the grille.
I'm not happy with the antenna location (performance wise) and may install it on the roof rack using a folding base - perhaps a motorised folding base, e.g., Diamond K9000 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #664744 23rd May 2023 6:17am
