Home > Technical (L322) > Battery's
TheJohnnyH
United Kingdom 2010 Range Rover Vogue TDV8 Bournville
Battery's
Hey. New owner of 3.6 TDV8 and battery dead after 10 mins watching TV with engine off. Now it won’t turn over. When I bought it I was told they recently replaced the battery but there is no receipt in the history. Is this up to the job? Lion 95ah EN 750 CCA ?
Cheers
Post #566445 6th Sep 2020 5:10pm
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Lion battery. Not worth the sticker that's on it. Enough said. 2006 4.2 SC
Post #566446 6th Sep 2020 5:19pm
TheJohnnyH
What is best to replace it with?
Post #566449 6th Sep 2020 5:44pm
Gold Ranger
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
if you have start stop you will need a AGM if not then a normal battery will do
on mine i have bosch one that came with the car , i have had the car a year now and never had any problems with the battery
in the links is a list of different brands of agm & normal batteries what ever suits your wallet
AGM; ones
https://www.tayna.co.uk/car-batteries/types/020-agm/
Normal ones
https://www.tayna.co.uk/car-batteries/types/020/
Post #566451 6th Sep 2020 5:56pm
TheJohnnyH
Thanks
Post #566452 6th Sep 2020 6:09pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
Gold Ranger wrote:
for a start Laughing Laughing it needs to be a Agm one as you have start/stop on yours
why do you state that it has stop / start? - mine is a 2010 3.6 TDV8 (one of the last 3.6 before 4.4) and doesn't have stop/start
i also believe (check) that not all 3.6TDV8 had AGM batteries (though mine does) and that in any case, whether an AGM battery is fitted or not, this detail can be set up using an IID device.
my 2010 SLK (which did originally had an AGM) had a non-agm battery fitted about 4 years ago which has been fine even without telling the management system that the baattery is no longer AGM.
Post #566462 6th Sep 2020 8:45pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Do not, under any circumstances, buy an 020 battery - it will fit in the space but you won’t be able to connect to the positive terminal.
I covered this in detail in my post a few months ago.
Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #566474 7th Sep 2020 5:35am
RobWheatley
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
The 020 does fit, just fitted one to my TDV8, just had to move the big fuse from the side of the terminal to the top. 2010 L322 3.6 TDV8 Vogue Stornaway Grey
Post #566529 7th Sep 2020 5:57pm
TheJohnnyH
This is what I’ve been told I need from Euro car parts. Going for the Boshe I think if it’s the correct one.
Post #566533 7th Sep 2020 6:37pm
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Take yer pick. https://www.tayna.co.uk/car-batteries/types/019/
Post #566535 7th Sep 2020 6:53pm
TheJohnnyH
The one euros are recommending is like £230 + VAT
What am I missing here? The Bosch’s one in your list is less than half that. Is it the same battery. What should I be looking for? Very confused.
Post #566542 7th Sep 2020 7:41pm
Bloke
Your price is for AGM. Lower price linked to is for standard lead acid.
https://www.yuasa.co.uk/info/technical/agm-efb-explained/
Post #566544 7th Sep 2020 8:02pm
TheJohnnyH
Thanks. I need AGM right? From what I can tell from the threads I have read. It seems to be worth the extra money?
Post #566545 7th Sep 2020 8:07pm
Bloke
Pop yer reg number in here https://www.yuasa.co.uk/
Probably just a standard lead acid '019' that's required?
Post #566547 7th Sep 2020 8:15pm
TheJohnnyH
Post #566549 7th Sep 2020 8:25pm
