![]() | Home > Technical (L322) > Battery's |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
Lion battery. Not worth the sticker that's on it. Enough said. 2006 4.2 SC |
TheJohnnyH Member Since: 01 Sep 2020 Location: Kent Posts: 23 ![]() ![]() ![]() |
What is best to replace it with? |
Gold Ranger Member Since: 31 Mar 2017 Location: East Midlands Posts: 33 ![]() ![]() ![]() |
if you have start stop you will need a AGM if not then a normal battery will do
Thanks |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
why do you state that it has stop / start? - mine is a 2010 3.6 TDV8 (one of the last 3.6 before 4.4) and doesn't have stop/start i also believe (check) that not all 3.6TDV8 had AGM batteries (though mine does) and that in any case, whether an AGM battery is fitted or not, this detail can be set up using an IID device. my 2010 SLK (which did originally had an AGM) had a non-agm battery fitted about 4 years ago which has been fine even without telling the management system that the baattery is no longer AGM. |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 ![]() ![]() ![]() |
Do not, under any circumstances, buy an 020 battery - it will fit in the space but you won’t be able to connect to the positive terminal.
RobWheatley Member Since: 10 Mar 2019 Location: Yorkshire Posts: 37 ![]() ![]() ![]() |
The 020 does fit, just fitted one to my TDV8, just had to move the big fuse from the side of the terminal to the top. 2010 L322 3.6 TDV8 Vogue Stornaway Grey |
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
Take yer pick. https://www.tayna.co.uk/car-batteries/types/019/ |
The one euros are recommending is like £230 + VAT
Your price is for AGM. Lower price linked to is for standard lead acid.
Thanks. I need AGM right? From what I can tell from the threads I have read. It seems to be worth the extra money? |
Pop yer reg number in here https://www.yuasa.co.uk/
