Home > Technical (L322) > EPB
Fox889
EPB
Strange one here......while waiting to enter Brighton Caravan Site we had to queue on a slope leading to the campsite.
Laden caravan on the back, slipped the girl into Neutral, foot on brake pedal, apply EPB, release foot pedal..........car creeps forward! Tried this several times and each time she wouldn't hold, slightly unnerving keeping one's foot on the brake pedal all the time.
I can only assume the weight of the caravan bearing down on the towbar plus the fact we were 'pointing downhill' fooled the EPB into not fully engaging? Or is it a sign of weak shoes etc.
She's in for her annual service/MOT in a fortnight so not overly bothered but just thought someone may have an idea? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
BMW R1200GS
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #564784 17th Aug 2020 3:56am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Put it in Park instead of Neutral, wont go anywhere then. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #564785 17th Aug 2020 4:19am
Fox889
Thanks AJ, always worried about any strain on the 'P' side of the gearbox after you put her in 'P' then release the foot brake, there's a lot of weight bearing down on that 'box & the same again when you de-'P' it?
I still don't understand why she wouldn't bite when the EPB was activated, I've had a good look on 'search' on here, but nowt lad Razz 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
BMW R1200GS
Post #564787 17th Aug 2020 4:29am
DrRob
A lot of places "forget" to adjust the EPB on the annual service. I specifically ask my local place (and mate mechanic) to do it so I know it's been done. Easy to do if you wanted to DIY....
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #564788 17th Aug 2020 7:01am
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Adjust the EPB shoes, same as you would with any drum brake system.
Follow the correct EPB drive cycle to set the shoes.
Read https://media.disco3.co.uk/gallery/albums/...1.4sml.pdf
Best, Rich L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #564789 17th Aug 2020 7:04am
Fox889
So, can I assume that the creeping forwards shouldn't have happened, even downhill slightly with near 2ton of tin behind? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
BMW R1200GS
Post #564791 17th Aug 2020 7:59am
AJGalaxy2012
The brake shoes may need adjusting. There is very little force on the gearbox compared to when your dragging your tintent around, you have nothing to fear in using Park. BMW i3 Electric Car
Post #564795 17th Aug 2020 8:37am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
It should hold the car on its own.
Don't know if any handbrake could be trusted with 3 tons of RR + 2 tons of caravan + a hill. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #564796 17th Aug 2020 8:39am
AJGalaxy2012
Mine held with 2 Tonnes behind it on a steep hill no problem BUT they do need correct adjustment, good shoes and good drums. BMW i3 Electric Car
Post #564798 17th Aug 2020 8:41am
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Mine holds the FF snd the the 3.5 tonne boat trailer on the back on a slip way (steep hill) just needs to be adjusted once a year.
Post #564799 17th Aug 2020 8:51am
D3Jon
I had a similar issue with our's and despite adjusting the brake shoes correctly, the EPB still wouldn't hold well.
I recently changed the handbrake shoes at the same time as rear discs (which gives you new handbrake drums of course), adjusted them up, went through the bedding in process and have a cracking handbrake now.
The old shoes had plenty of lining left on them, but at (probably) 8 years old were passed their best and did look a bit glazed to me.
Regards,
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #564978 19th Aug 2020 9:52am
Fox889
Thanks for all your input, I've asked the Indy to add EPB to the service list.
Just looking at those last pics, the handbrake system/size isn't massive Laughing 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
BMW R1200GS
Post #565006 19th Aug 2020 2:51pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
If you are on a downward slope the caravan would be "catching" the tow vehicle so would it not make the caravan brakes operate so your handbrake is only actually holding the vehicle 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #565019 19th Aug 2020 5:42pm
lighthouse
Very true but when your backing a boat down a slip way its the opposite and all the weight is on the car brakes.
Post #565038 19th Aug 2020 7:41pm
