Home > Technical (L322) > EPB |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Put it in Park instead of Neutral, wont go anywhere then. BMW i3 Electric Car
17th Aug 2020 4:19am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 682 |
Thanks AJ, always worried about any strain on the 'P' side of the gearbox after you put her in 'P' then release the foot brake, there's a lot of weight bearing down on that 'box & the same again when you de-'P' it?
17th Aug 2020 4:29am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
A lot of places "forget" to adjust the EPB on the annual service. I specifically ask my local place (and mate mechanic) to do it so I know it's been done. Easy to do if you wanted to DIY....
17th Aug 2020 7:01am |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
Adjust the EPB shoes, same as you would with any drum brake system.
17th Aug 2020 7:04am |
So, can I assume that the creeping forwards shouldn't have happened, even downhill slightly with near 2ton of tin behind? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
17th Aug 2020 7:59am |
The brake shoes may need adjusting. There is very little force on the gearbox compared to when your dragging your tintent around, you have nothing to fear in using Park. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
17th Aug 2020 8:37am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 688 |
It should hold the car on its own.
17th Aug 2020 8:39am |
Mine held with 2 Tonnes behind it on a steep hill no problem BUT they do need correct adjustment, good shoes and good drums. BMW i3 Electric Car
17th Aug 2020 8:41am |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
Mine holds the FF snd the the 3.5 tonne boat trailer on the back on a slip way (steep hill) just needs to be adjusted once a year. |
17th Aug 2020 8:51am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 418 |
I had a similar issue with our's and despite adjusting the brake shoes correctly, the EPB still wouldn't hold well.
19th Aug 2020 9:52am |
Thanks for all your input, I've asked the Indy to add EPB to the service list.
19th Aug 2020 2:51pm |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 369 |
If you are on a downward slope the caravan would be "catching" the tow vehicle so would it not make the caravan brakes operate so your handbrake is only actually holding the vehicle 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
19th Aug 2020 5:42pm |
Very true but when your backing a boat down a slip way its the opposite and all the weight is on the car brakes. |
19th Aug 2020 7:41pm |
