Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Ah ok that's making sense now. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
11th Jan 2020 7:50pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3195 |
Hi Greg,
16th Jan 2020 12:44pm |
I’d give them a ring DB.
16th Jan 2020 3:47pm |
Previous Situation - DPF red Warning present/Restricted Power/DPF reading 29g of soot/LR dealer unable to force regen due to level being over 28.5g (the limit of their LR software capability)
27th Jan 2020 2:40pm |
If a LR dealer can't clear a EML then time to go.
27th Jan 2020 5:55pm |
Right, just had my car back from the LR dealer having had a red dpf light come on and not able to clear - had rear sensor replaced. They couldn’t force regen the dpf (they got lower soot readings but the engine Ecu failed to recognise the lower reading and it remained in restricted power with red light on.)
7th Feb 2020 9:19pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
That's awesome Dolphinboy. I recommend you add "number of demanded regens" to your IIDTool and maybe "total distance" too then you can see exactly when it asks for a regen as well as easily see the mileage vs the soot.
7th Feb 2020 10:02pm |
duplicate |
7th Feb 2020 10:03pm |
Roger will do |
7th Feb 2020 11:07pm |
paulparry82 Member Since: 04 Mar 2020 Location: Merseyside Posts: 21 |
Morning All
9th Aug 2020 10:25am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4313 |
Step 1 is check for splits in the 4 plenum hoses. Whip off engine cover and see if you have the original hoses on there. Take a picture and post it on here. More information: https://www.fullfatrr.com/forum/topic56424.html
9th Aug 2020 10:36am |
Thanks for the response - the inlet manifold was removed and reinstalled during the coolant system works. The hoses look like the original ones judging from the photos in the link. I'll have a look to make sure clips are tight and check for any soot beenath etc.
9th Aug 2020 11:07am |
This is addition - and after what Dr. Rob says
9th Aug 2020 11:33am |
Thanks Greg - sorry, I thought IID was a generic term for the diagnostic tool. I bought the Icarsoft to do the battery reset when I changed the battery last year. There is an option to tell the ECU it has had a new DPF filter. Might look at the IID tool as an option, might prove useful to have.
9th Aug 2020 11:48am |
